Hi-end 845 with only two stage
Old 24th August 2011, 05:53 PM   #241
gaborbela is online now gaborbela  Canada
Hello Thomas
I have more than 20 years DIY experience, also I work as a assistant in TV repair shop and with electrician mostly residential but sometimes in factory with 360V to.
I have some soldering skills that is not a problem.
I have more than half of the parts for these amp, I go slowly how I get some money..
If there is a working schematic I can build anything.
I do not own oscilloscope etc but probably I can get some help from my friend. Some DD Multimeter etc I have of course.
Greetings gabor
Old 24th August 2011, 07:19 PM   #242
Vinylsavor is offline Vinylsavor  Germany
Vinylsavor's Avatar
Hi Gabor,
ok that's good. Just wanted to make sure since there are dangerously high voltages involved in such a project
Best regards
Thomas
http://vinylsavor.blogspot.com/
Old 24th August 2011, 08:19 PM   #243
Thank you Thomas
I know,I thought about before I started to collect the parts!
Safety first.
I think these 2 stage will be better than the schematic I posted. Even do I'll purchased some 6SN7 & 6J5 tubes also octal sockets..
I see Andrea and many other (guru) DIY-ers go with two stage.
Someone told me avoid the instage transformer, use just tubes but I think the transformer still better than many coupling capacitors.
I attache some picture from the parts I already have..
12PC Epcos
3PC amplifier enclosure, two the same as on the picture, one larger for PS
4PC GM70, 2 socket
high voltage choke - about 3.5Kg, 12PC electrolytic etc.
Greetings gabor
Old 25th August 2011, 06:50 AM   #244
Default Fiat OPT
Hello Andrea
How much it cost a pair Fiat OP transformer for GM70. I think 25-30W would be enough.
Please let me know
Thank you very much
Greetings gaborbela
Originally Posted by audiodesign View Post
gaborbela,
look this dc solution
GM70 amplifier with Fiat transformers
Hi-end 845 with only two stageHide this!Advertise here!
Aikido line stage - plus phono line stage cjkpkg Tubes / Valves 1 22nd November 2008 09:50 PM
Output stage biasing, with the driver stage andrew_whitham Tubes / Valves 0 19th May 2007 11:14 AM
Should I replace Scott 222C phono stage with Claret phono stage? Bing Yang Analogue Source 0 22nd August 2005 06:41 AM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 04:07 AM
Dsd without D/A stage.... kyrochan Digital Source 15 30th March 2005 04:36 PM
Copyright ©1999-2017 diyAudio
