KT88 Recommendations? - Page 2 - diyAudio
Old 5th November 2008, 07:45 PM   #11
Thanks for the input, I think I will go with the EH KT88's. Probably order them from Jim McShane. Still a few weeks from making the final determination.
Old 10th January 2010, 05:22 PM   #12
Default JJ KT88's internal short/fail?
About a year ago, I purchased a matched pair of JJ KT88s from Triode Electronics. About two weeks ago, I noticed the inside of one tube glowing brilliant white. Looking inside more closely, the grids were glowing white. I swapped the tube positions, and the problem moved ... so I know the tube is suspect.
Grid bias set for cathode at 1 volt. Basically a stock amp but with the filter cap board upgrade from Triode and a silicon diode replacing the selenium. All PS voltages are at spec.
How often do JJ KT88 tubes have this kind of failure? I wrote to Triode but do not have a reply yet.
I did not physically remove the ancient can electrolytic in-view. But, it's disconnected.
Thanks.
SE KT88 Amp Cassiel Tubes / Valves 50 24th March 2011 08:33 PM
2A3 or KT88 ? 6J7 Tubes / Valves 8 19th April 2009 11:52 AM
Help - CFB in a KT88 SE amp Drewaudio Tubes / Valves 4 30th January 2007 04:36 AM
Kt88 Se hacknet Tubes / Valves 9 10th September 2004 08:19 AM
Drd Kt88? hacknet Tubes / Valves 13 26th August 2004 03:41 PM
Copyright 1999-2017 diyAudio
