| diyAudio Sponsor | ||
I have a rare pre-amp that I had asked a tech who did some work on it to disconnect the phono stage. Unfortunately, he's long gone and I'm having trouble reconnecting it up. I found the HV wires that were disconnected and reconnected them but I still have no output from the phono.
I know its something simple I'm not seeing. There are two other disconnected wires but they contain negative voltage and is coming off the filament. I suspect its a negative bias but it measures a proper 1.6 negative bias without them hooked up. Is anyone in the Los Angeles or West Los Angeles area that would be willing to look at it and say, "Why you idiot! You just need to ....." (' |
#2 |
I can help out...
I work in Manhattan Beach at Northrop Grumman...The big white building next to the 405 at the Englewood Ave exit.. I go up to Santa Monica to eat at some restaurants after work... Email me .. Chris |
#3 |
Thanks Chris! Email sent.
#4 |
Never heard from Chris and now I need to fix this before my amps are sold. Is there anyone else in the area? I sure would appreciate the help.
#5 |
Thought I'd finish the story. A tech who reads this board was kind enough to come over and discover it was a disconnected wire.
| tube amp repair in DFW area | tomcat9 | Tubes / Valves | 0 | 13th July 2009 10:29 PM |
| Looking to "Borrow" an Amplitrex, 539C or other High-End Tube Tester in SE PA Area | baileyler | Swap Meet | 0 | 14th January 2009 02:07 PM |
| Hi from Los Angeles area PA7 owner | kzim229 | Introductions | 3 | 5th August 2008 03:56 AM |
| Speaker Tech needed in Los Angeles area | dmfraser | Multi-Way | 2 | 3rd November 2004 11:18 PM |
| Any Tube DIYers in Bay Area | effindi | Tubes / Valves | 4 | 7th April 2004 11:25 AM |
| Page generated in 0.07533 seconds (78.63% PHP - 21.37% MySQL) with 10 queries |
