diyAudio Sponsor
Old 2nd March 2009, 01:05 AM   #41
wrenchone's Avatar
With the triode/Jfet input solution in mind, I'm going to spend some time tracing load lines to make sure that the Jfets will survive even under extreme overload/overdrive (happens all the time...) I may need to add clamps on the Jfets to protect them. The Jfet/triode combination is not the most cascodey of cascode solutions, as the Jfet drains will wander around some with drive extremes. but I'm more interested in protecting the Jfets than I am providing an ideal cascode environment. If I use Jfets like the PN4393 and J309/310 with low miller capacitance, this will not be a big concern. With the 2SK170s, I'd have to look into it a little more.
Old 3rd August 2010, 04:24 AM   #42
wrenchone's Avatar
I've been wobbling back and forth as to what output iron to use, then an opportunity came by that settled things. An Ebay seller offered output transformers meant for a 160-200W guitar amp. I nabbed a pair at a price lower than a comparable Edcor offering. Initial measurements indicate that they are 7k:8 units, with a primary inductance of a whopping 600 H, measured with a sine wave input of 100V, 300 Hz. They weigh in at 11 lb apiece. I think I will have low end extension if I want it. I suspect these were intended for use with selected tubes at 700V B+ or so to get the stated output rating. I'll need around 650V B+ to reach my stated goal of 100W per channel. With this turns ratio, any sweep tube worth its salt will laugh at the voltage and current.
Chip amps used in "push pull" ChrisA Chip Amps 22 2nd July 2009 10:18 PM
Initial Thoughts for "Mr. Piggy" SE Amp w/Screen Driven 6P45S wrenchone Tubes / Valves 9 4th January 2009 11:39 AM
Finished - Pics of my new push-pull subwoofer with 2 x 12" + Bash amplifier :) Xmax BR Subwoofers 26 11th March 2007 10:16 PM
Kofi Annan in: "Push and Pull with Me" Kofi Annan Tubes / Valves 340 6th November 2006 04:18 AM
LP Morgan Rondo Pull Down 82" 16:9 Projector Screen NicolasGaal Swap Meet 2 25th January 2004 04:26 AM
Page generated in 0.07916 seconds (69.68% PHP - 30.32% MySQL) with 10 queries
