diyAudio Sponsor
Old 27th October 2008, 11:36 PM   #1
nhuwar is offline nhuwar  United States
nhuwar's Avatar
Default filter choke voltage rating
I've heard that you can put you power supply filter choke on the grounded side of your supply so you don't need a high insulation rating.
My question is will this work for audio, I read it in an ARRL handbook. I don't see any reason why it wouldn't but I wanted to ask first.
Thanks,
Nick
Old 28th October 2008, 12:13 AM   #2
SY's Avatar
Sure, you can put the whole filter there.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 28th October 2008, 12:17 AM   #3
nhuwar's Avatar
So there won't be any adverse sonic effects?
Nick
Old 28th October 2008, 02:45 AM   #4
No there won't be any sonic effects. Just make sure the 0V connection is AFTER the choke. This often done in Single Ended Triode Amps using tubes like an 845 which sounds best with anode voltages up around 1100 to 1200 volts. In fact nearly every one of these I've seen had the choke in the "ground" side of the power supply. it is simply safer there rather than sitting with 1200 Volts on it.
Ian
Choke Rating Reima Power Supplies 4 28th May 2008 07:15 AM
Choke rating for choke input duty cbutterworth Tubes / Valves 14 9th November 2007 04:43 PM
way to estimate choke current rating? astouffer Tubes / Valves 8 15th October 2007 08:37 PM
Using a cap above its voltage rating? h_a Parts 10 6th October 2007 03:46 PM
choke current rating metebalci Tubes / Valves 17 9th August 2004 08:51 AM
Page generated in 0.08342 seconds (74.61% PHP - 25.39% MySQL) with 10 queries
