| diyAudio Sponsor | ||
I have finished an ST70 build and found one of the EL34B's dead.
I have ordered a new matched pair ? Do I put the new matched pair both on one channel/side or do I split them and mix with the other two matched pair for the best results ? Do I need to rebias after putting in replacement (same type) tubes ? I am sure this may be a trivial question but I would appreciate your thoughts. As a fianl question, do I run any chance of damaging the amp if I run with three operative EL34B's while waiting for the replacements ? |
#2 |
Use the matched pair in one channel- their matching controls the ripple rejection and distortion. The "odd" tube from the pair can be kept as an emergency spare, but unless you can find another tube matched to it, it will be less than optimal.
Yes, you will need to rebias. Check it often for the first 10-20 hours of tube use. Would you run your car without one of the rear tires?
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#3 |
Hi mt1962,
I'll just add to this. Order a matched quad. It doesn't cost any more than two matched pairs and you can just stick them in. Then after wearing, you may find the pairs match better another way. Do not run only one tube in a push pull amp. -Chris
"Just because you can, doesn't mean you should" © my Wife |
| Matched tubes or not matched | hilbert_mostert | Tubes / Valves | 29 | 27th March 2009 10:13 PM |
| matched tubes? | webelo | Tubes / Valves | 6 | 16th December 2007 10:57 PM |
| Matched tubes required? | porkchop61 | Tubes / Valves | 3 | 10th May 2007 08:11 PM |
| WTB: A matched pair of WE 396A Tubes | cartman | Swap Meet | 0 | 22nd November 2006 10:42 AM |
| do pp output tubes have to be matched? | 9am53 | Tubes / Valves | 12 | 17th March 2005 09:01 PM |
| Page generated in 0.07156 seconds (69.84% PHP - 30.16% MySQL) with 10 queries |
