| diyAudio Sponsor | ||
Does anyone know what TV damper diodes are? Help!
Heard they're great for rectifiers. Jack T. |
#2 | |
diyAudio Senior Member
This should enlighten you: From the Svetalna website: Quote:
6D22S Hope it helps,
Frank |
#3 | |
#4 |
They're known in the UK as efficiency diodes because they greatly increase the efficiency of a TV line scan circuit during flyback compared to the older method that used a resistor to damp the oscillation. They are rugged and cheap, so they make good rectifiers, but they usually have top cap anodes (to withstand the 2kV needed for TV flyback), so they should be treated with a healthy respect.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#5 | |
diyAudio Moderator Emeritus
Cheers, |
#6 |
You're absolutely right, whatever was I thinking of? Mind you, as an HT rectifier, accidentally catching the cathode will still hurt!
#7 |
Yes, you vibrate more
Cheers, Edit... I should have said less!!!! |
#8 |
To resurrect this hoary old thread, I just wanted to ask if anyone is aware of any sonic disadvantages of dampers, with respect to directly heated types like the 5U4? My personal feeling is that nothing sounds better than dampers but I don't have any first-hand experience of filamentary rectifiers.
#9 |
Right there with the previous question; is anybody using 6d22s at low voltages + low current draw? I heard (say) they need some juice to sound okay.
Simon |
| damper diodes .... | sunrise | Tubes / Valves | 2 | 5th November 2008 10:05 PM |
| tv damper diodes | jarthel | Tubes / Valves | 1 | 19th April 2007 03:41 AM |
| TV Damper Diodes | CarlyBoy | Tubes / Valves | 5 | 19th November 2006 09:20 PM |
| Damper Diodes | hacknet | Tubes / Valves | 5 | 5th May 2004 08:35 AM |
| Page generated in 0.10137 seconds (78.77% PHP - 21.23% MySQL) with 10 queries |
