| diyAudio Sponsor | ||
Hey all,
I have just acquired a Quickie 8417 with 6550/5AR4/12AX7/12BH7 setup. I took a peak inside and found the coupling caps have been changed out to .22uF 1000V, two electrolytic caps added to the Bias pot (seems to be on front side, not on back, and original 60uf 160 is still on back end of pot by diode), and the diode mod on the rectifiers seem to be the only mods done on the amp. All else looks stock. Question is this. If 6550 bias is stable at 100 or 110ma, are the other mods required? I was under the understanding that a lot of the mods were devised to keep the amp stable with other tubes.... Any other mods "Must Do"? I have just purchased four .22uf 600V Russian FT3 after hearing a lot of good buzz about them...but going to be a little tight in the chassis...not quite sure I will put them in... Also, could a 6L6GC be subbed in for the 6550 (I have a few of them laying around)
"I speak Spanish to God, Italian to Women, French to Men, and German to my Horse" - Charles V |
#2 | ||
Jeff |
| Quicksilver 8417 conversion | Original Burnedfingers | Tubes / Valves | 25 | 18th December 2011 10:33 AM |
| quicksilver 8417 biasing | ozdiyer | Tubes / Valves | 2 | 26th August 2007 07:54 PM |
| quicksilver 8417 hum | dreaded 42 | Tubes / Valves | 4 | 11th September 2003 02:45 AM |
| Quicksilver 8417 | dreaded 42 | Tubes / Valves | 4 | 4th September 2003 11:14 PM |
| Quicksilver 8417 model changes | Original Burnedfingers | Tubes / Valves | 3 | 12th April 2003 02:45 PM |
| Page generated in 0.06602 seconds (68.89% PHP - 31.11% MySQL) with 10 queries |
