| diyAudio Sponsor | ||
I've decided to ditch the dynaco and eico design. Has anybody built the Lundahl 4-30 amplifier? how is it? and can I use the Antek AN-4T360 for the stereo power supply and an Hammond 1645 for the output transformer? How would I go about getting the bias voltage? Thanks again for all your help.
#2 |
I built the 4-30 two years ago. Very happy with it. I did use other trannies but I then had to modify the circuit to make the amp stable. It occilliated, and we had to lower the value of the coupling caps.
#3 | |
Dude, The 4-30 uses Mullard style circuitry. With all respect to Claus Byrith, the use of high RP/low gm small types is (IMO) ill advised. Two very important considerations in amps with loop NFB, like the Mullard style, are slew limiting and O/P trafo core saturation. High gm small signal types provide resistance to slew limiting. My previous recommendation of 12BH7 and 12AT7 small signal types stands. The overall gain structure of the 2 selections is very similar. An added benefit of the 12AT7's presence is a superior net harmonic distortion spectrum. By all means, use CB's "fixed" bias PP O/P stage, with complete confidence.You will have little trouble in using the AN-4T360 power trafo. Connect the 2X 360 VAC windings in parallel. Bridge rectify with snubbed UF5408s on the ground side and 600 PIV Schottky diodes on the B+ side. Install a CL150 inrush current limiting thermistor in the line between the rectifier bridge and the PSU filter. CLC filter the B+. Start with 1.5 μF. in the 1st position and adjust that value, with the PSU loaded down, to bring the B+ rail in at 440 V. No less than 5 H. are required in the choke. Pile the energy storage up in 2nd position. As the AN-4T360's filament windings are lightly loaded (no vacuum rectifiers), use 1/2 of 2X 12BH7s in each channel. Wire 1 channel to use system #1 and the 2nd channel to use system # 2. When the tubes wear out, flip/flop them. IMO, the Hammond 1645 O/P trafo is a very poor choice. Its end to end impedance is somewhat high for this application and its power handling capability is woefully inadequate. O/P core trafo saturation is dealt with by rolling low freq. info. off at the amp's I/P. To keep the NFB error correction signal from saturating the core of a 1645, the I/P high pass "corner" freq. will be high enough to foul the music up, very badly. Sorry, TANSTAAFL. Greinacher ("full wave") voltage double a "Rat Shack" catalog # 273-1366 to derive the EL34 bias voltage. Pay CLOSE attention to the remark about oscillation. Notice the 560 pF. cap. in parallel with the NFB resistor. That's a phase compensation part. Its value is tied to the character of the O/P "iron" used. The proper value is determined with an o'scope and a 10 KHz. square wave. I suggest a brute force method for phase compensation. Use inductive wirewound resistors as phase splitter plate loads. That peaks HF gain. Short the NFB loop out above 80 KHz. by connecting a cap. between the "hot' speaker lead and ground. This method relies on the natural HF rolloff of the O/P trafo and an o'scope is not needed.
Eli D. |
#4 |
Thanks for the help, if the 1645 is a poor choice, then what can you suggest that would work better? preferably Hammond. Can you post a schematic of the 12bh7 and 12at7 preamp? I can take the bias voltage by putting the filaments in series and voltage double it right? thanks for the help, I really appreciate it
#5 |
The Edcors look really attractive, I might go with a pair of these CXPP60-8-4.2K, they seem to be a good option at a very fair price. It's shipping here and the exchange that'll kill me, but I'll try to get some numbers, they'll probably be way cheaper then hammonds.
#6 | ||
Eli D. |
| Lundahl LL1540 | ErikdeBest | Swap Meet | 7 | 22nd July 2009 08:29 AM |
| Where can i get Lundahl transformers? | yangsmm | Parts | 3 | 13th June 2008 02:00 AM |
| Lundahl LL1527XL | hifi | Swap Meet | 1 | 1st July 2006 12:28 PM |
| Lundahl 1660 | joe845 | Swap Meet | 0 | 30th December 2004 11:33 AM |
| 845 PP and Lundahl 1620 | audiobot | Tubes / Valves | 187 | 22nd June 2004 11:48 PM |
| Page generated in 0.08459 seconds (85.74% PHP - 14.26% MySQL) with 10 queries |
