diyAudio Sponsor
Old 22nd October 2008, 09:21 PM   #1
Default Soft starting the rectifier
A CL150 in the B+ line after the rectifier is often used to cushion the start a little bit. Seems like a very good idea but I was wondering about putting the CL150 directly in the heater circuit between the filament and the transformer. The idea being to soft start the rectifier's filament easing the flash heating of the filament and also delaying B+ slightly. The recto in question is 5U4GB.
Thoughts?
mike - www.keepingsundayspecial.org
Old 23rd October 2008, 04:02 AM   #2
SpreadSpectrum's Avatar
It might work if you wanted to run the heaters low. CL150 has a steady state resistance of .11 Ohms at 4.7A. That is a drop of about half a volt. The resistance increases if used with less steady state current. Maybe this could be used to correct filament voltages that are too high. Seems like it might work well with a Hammond transformer...
I usually use CL140 in B+(50 Ohms cold, 1.1A max). It seems like it would work a lot better than CL150 (5 Ohms cold, 4.7A max) in that position , unless you are pulling a heck of a lot of current. 5 Ohms cold from the 150 won't give you much benefit, either.
Bridge rectifier vs Full wave rectifier hilbert_mostert Tubes / Valves 4 28th April 2009 08:26 PM
Soft start & Soft Switch circuit: can anybody help? m.parigi Solid State 95 22nd August 2005 03:32 PM
Anybody heard about Tarzian Silicon Rectifier for Tube Rectifier Replacement? zxx123 Tubes / Valves 4 21st February 2005 04:02 AM
Integrated Rectifier Bridge VS Rectifier Diodes Sci Chip Amps 11 16th July 2004 02:43 PM
Soft starting big toroids Jason Hubbard Solid State 17 7th June 2001 02:51 PM
Page generated in 0.08146 seconds (70.88% PHP - 29.12% MySQL) with 10 queries
