diyAudio Sponsor
Old 22nd October 2008, 09:10 PM   #1
reap461 is offline reap461  United Kingdom
Default Tube preamp components help
can anyone with any AUDIO electrical knowledge look at this file and recomend values for the few missing components as i am stuck in a middile of a build it is a jts preamp but moded for a valve output system however parts of the original components was destroyed and have black spray paint over them so its not possible to get a reading with a multimeter. the missing components are on the bass and mids settings which start roughly around c43 so can anyone please please help as it will be greatly appreciated thanks
http://hosted.filefront.com/reap461/
Old 23rd October 2008, 05:02 PM   #2
kevinkr's Avatar
The circuit is a gyrator of some sort, beyond that I can't really say. It only drives that LED circuit at least drawn as shown. Seems like this ought to be posted on another thread..
www.kta-hifi.net
FA: Eico HF-85 Tube Preamp & HFT-90 Tube Tuner joe-electro Swap Meet 0 31st May 2009 04:14 PM
Preamp Components reap461 Everything Else 0 21st October 2008 10:45 PM
Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps MartyM Tubes / Valves 3 16th October 2008 04:52 AM
need diy tube preamp (line-stage) recommendation and general tube advice Musiclover4 Tubes / Valves 15 24th November 2005 01:19 AM
Components for tube Amp JDeV Parts 1 10th March 2003 04:18 PM
Page generated in 0.05948 seconds (69.91% PHP - 30.09% MySQL) with 11 queries
