| diyAudio Sponsor | ||
If running a stereo single ended amp with fixed bias, is it really a problem to have the filament supply shared? I could maybe see an issue when it comes to hum pots, but other than that, is it really an issue?
-Paul |
#2 |
Depends on how you share it. I've seen some budget setups where a single AC filament supply was used for a pair of outputs with a common self-bias resistor and bypass cap via the center-tap. Granted it works, but wherever the hum levels wind up, there you are... no ability to adjust.
I would suggest using a DC supply as AC filaments will still yield some hum with fixed bias. In particular which DHT are you planning on using? I have found that NOS 45 in ST glass tend to balance well (using a padded hum pot) with AC, better than most 2A3 (dual-paralleled triodes) DHTs. A single plate 2A3 is a nightmare with AC filament, pretty much the same for a 300B due to the center-tapped filament setup. Regards, KM |
#3 |
I did it using a single voltage supply and a separate CCS for each filament.
![]() http://www.ecp.cc/less-pressivo-plus-plus.html
http://www.ecpaudio.com |
| Fixed bias: Pots near supply or tubes? | DrewP | Tubes / Valves | 10 | 23rd July 2009 12:17 AM |
| DHT bias and filament supply in one? | dsavitsk | Tubes / Valves | 7 | 10th July 2009 04:50 AM |
| Finding bias point in PP fixed bias | beamnet | Tubes / Valves | 14 | 7th December 2008 01:25 PM |
| Battery grid bias to fixed bias in Toccato? | w00t | Tubes / Valves | 3 | 2nd December 2007 12:34 AM |
| Fixed bias supply problems... | SHiFTY | Tubes / Valves | 3 | 31st August 2004 11:22 AM |
| Page generated in 0.07699 seconds (68.32% PHP - 31.68% MySQL) with 10 queries |
