diyAudio Sponsor
Old 20th October 2008, 02:23 AM   #1
Send a message via ICQ to eranrund
Default TL783 regulated B+ 250V PSU schematic
Hello gentlemen,
Below is my attempt at a regulated 250v PSU, for driving two E88CC triodes.
Any comments/suggestions?
All capacitors except 10uF are Aluminum Electrolytic, 10uF are MKP.
Resistors are metal film 5%, 2W.
I tried searching the forum for similar designs but nothing concrete came up.
Old 20th October 2008, 07:09 AM   #2
mach1 is offline mach1  Australia
mach1's Avatar
I would lose the large 100uF cap on the output as well as the 470R series feed resistor which raises the nice low output impedance of the TL783.
Au rutti wop-bop-a-loom-bop-a-boom-bam-boom - Richard Penniman
Old 20th October 2008, 01:30 PM   #3
jackinnj's Avatar
To "regulate" the TL783 needs to see at least 15mA load -- so you need current of this amount to flow from the output to adjust -- Texas Instruments recommends 82R.
Make sure that you use an adequately sized resistor from the adjust pin to ground -- at least 5 watts, preferably 7 watts.
So Output to Adjust 82R, Adjust to Ground 16K/7W.
The series resistor in the output -- omit this.
Read the data sheet from TI.
Old 20th October 2008, 09:19 PM   #4
Andypairo's Avatar
Well the datasheet actually states that the 15mA need to flow from the output, so you (only) have to ensure that the load current is > 15mA in any condition.
Cheers
Andrea
I don't believe in audiophile components - except when I can get them at frugal-phile(tm) prices
Old 20th October 2008, 09:37 PM   #5
jackinnj's Avatar
Yes but, no but, yes but, no but....
15ma across 82 ohms is 0.018 W.
15ma @250V is 3.75 W.
So, you're just burning energy -- if you're running a Class-A amp and the device is going to cook anyway -- it doesn't matter. If the load is going to vary all over the lot, then the lower value from OUT to ADJ is a better idea.
Anyone who runs a class-A amplifier will probably be hunted down by the next Stateside Administration. I hear that the Green Wing of the Dem party wants them outlawed -- and we'll all be listening to MP3's on Class-D amplifiers anyway.
Old 20th October 2008, 10:31 PM   #6
Renron is offline Renron  United States
Renron's Avatar
Jackinnj,
ROTFLMAO!
Well said. I'm putting nighttime covers on my tubes...
Ron
"If it doesn't work properly, hope it catches on fire"- Nelson Pass @ BA3
"I fired up the prototype. Literally." The Prophet Pass.
Old 20th October 2008, 10:56 PM   #7
Banned
This is a base slur. Class-D amplifiers yes, but nobody said anything about MP3s, which everybody knows are intrinsically more power hungry than uncompressed.
I know it's your politics, but the whole world's praying we don't get another idiot like the last one. Even us atheists.
w
I'm a republican too, it just means something different when you live in a monarchy.
Old 20th October 2008, 11:25 PM   #8
Renron's Avatar
Your entitled to your opinion....but not here. This is an inappropriate thread / forum for that type of comment. Let's stick to Audio related comments. OK?
Hey, I have my thoughts too, but this 'aint the place.
Personally, I don't like being told what I can or cannot do by my government. No one was called any names or attacked in the posting of this message.
Ron
(and I approve this message)
Old 21st October 2008, 12:49 AM   #9
jackinnj's Avatar
As long as you shield the Class-D amplifier in a Faraday Cage...
Getting back to the matter at hand, the TL783 would probably benefit from a MKP from adjust to ground -- this will knock down the noise quite a bit (although it isn't helpful for transient response, as TI points out.)
Just remember, JOBs is a 3-letter word, spread it around.
Old 21st October 2008, 01:39 AM   #10
wa2ise is offline wa2ise  United States
wa2ise's Avatar
I could have done better, and I have no political skills whatsoever...
Back to audio: I'd be worried if that regulator could take it if the output should get shorted to ground, or takes enough of a nosedive to overvoltage the regulator's ratings. The cap will look like a short for some brief period of time, long enough to kill the regulator. Instant chip death, and probably will blow shorted, feeding unregulated full B+ to the load. Doesn't take much to kill semiconductors, transients tubes laugh at will take out solid state.
PSU with TL783-question rotation Tubes / Valves 8 24th June 2008 10:51 PM
TL783 HV reggy richwalters Chip Amps 2 25th January 2008 06:05 AM
Anyone who have used the TL783 ? beppe61 Power Supplies 17 16th September 2005 04:05 PM
Help with regulated +/- 15V PSU schematic maxw Power Supplies 34 15th December 2004 08:13 PM
Page generated in 0.11518 seconds (80.45% PHP - 19.55% MySQL) with 11 queries
