How much ripple??
How much ripple??
Old 2nd April 2003, 12:01 AM   #21
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Default RIPPERS.
Why would more load on the supply lower ripple?
Only at start up would it help, once voltage has ramped up it wouldn't have that much impact, it clamps overvoltage.
Frank
Old 2nd April 2003, 06:23 AM   #22
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
Perhaps the hum comes from saturating transformers as the capacitors charge from 0V?
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 2nd April 2003, 05:09 PM   #23
Sch3mat1c is offline Sch3mat1c  United States
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
IMO, most likely hum caused by 1. capacitors charging and 2. tubes heating unevenly, resulting in momentary unequal hum cancellation. (When I pull the 12AX7 it hums again.)
Tim
Old 2nd April 2003, 11:05 PM   #24
fdegrove's Avatar
Default RE: RIPPLE.
How about: the less the better?
Pffffffffffffftttttttttt,
Frank
How much ripple??Hide this!Advertise here!
too much ripple steevo Solid State 11 5th July 2007 07:27 PM
measuring ac ripple with DVM? basildogann Power Supplies 2 31st March 2006 07:19 PM
How much ripple on B+ is allowed? Rundmaus Tubes / Valves 11 16th October 2005 02:19 AM
How do you measure ripple on the B+? porkchop61 Tubes / Valves 9 4th October 2005 11:51 PM
Measuring PSU ripple. How do you do it? Jonathan Bright Solid State 18 20th July 2004 11:07 PM
Copyright ©1999-2017 diyAudio
