| diyAudio Sponsor | ||
Forgive me on such a lame question, but why would a coupling cap (or any cap for that matter) in a tube pre or tube amp have to be rated any higher than its power supply caps?
I understand that in event of a problem, the cap could see full voltage, but why are there 630v caps on amps with 450v PS caps? Sorry - but it has been driving me nuts. The cost is a bit more for a .47uf 600v cap vs a .47uf 250v cap... If my B+ was 200v, why wouldn't 250v coupling cap work out just fine?
"I speak Spanish to God, Italian to Women, French to Men, and German to my Horse" - Charles V |
#2 | |
www.kta-hifi.net |
#3 | |
You defiantly want a coupling cap voltage rating to be at least equal to the B+ under worst circumstance. Think of start-up condition, a tube going bad, bad connection with the socket pin, accidentally powered up with no tube plugged in, or initial power up of an amp you mis-wired and haven't caught yet.. Your B+ will be higher than steady state (Just while the tube warms up if there is no fault) because it is not loaded down. Also during any of these conditions a coupling cap will see the full B+. Since the tube is not conducting yet, it is an open circuit. Which means the plate voltage will be the value of B+. So that is will be the voltage across the cap. Since one end is tied to the plate , and the other side of the cap is usually connected to grid resistor, which is at DC ground potential. Measure your B+ during initial start up, or un-loaded. If it does not significantly exceed 250V. There shouldn't be much of a problem using 250V coupling caps. |
#4 | |
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University |
#5 | |
#6 | |
#7 | |
Because if a PS cap blows, it is generally a smelly mess and not much more. If a coupling cap blows, it can mean taking out other components, other parts of your amp, or you.
http://www.ecpaudio.com |
#8 | |
The audiophool market has a large amount of custom "boutique" film and foil capacitors for sale at rip-off prices. However I see very little "custom" electrolytics being offered. It may also be interesting to know that electrolytic capacitors age oppositely from other types. They deteriorate when not in use on the shelf, but very little under power. Film and foils do just the reverse. Victor
#9 |
You might look at the classic article on caps ((picking audio capacitors)) walterjung.org/classic/articles.html
Well it seems that if manufacturer X has a 50v poly cap and a 600v poly cap the 50v cap will distort the signal just a little more than the 600v cap. But I read that article 25 years ago so I could be wrong..... |
#10 | |
http://waltjung.org/Classic_Articles.html
Robert McLean |
| Newbie Question on Driver Ratings | 6f6 | Multi-Way | 3 | 14th January 2007 11:58 PM |
| maybe this is too dumb a question... | dannyspencer | Solid State | 6 | 18th April 2004 04:57 PM |
| Thi is probably a dumb question.... | Konnan101 | Multi-Way | 4 | 11th January 2004 01:40 PM |
| A dumb question about coupling caps. | G | Tubes / Valves | 32 | 29th August 2003 07:26 PM |
| Page generated in 0.11589 seconds (83.90% PHP - 16.10% MySQL) with 10 queries |
