diyAudio Sponsor
Old 17th October 2008, 12:58 PM   #1
revintage's Avatar
Default Building PRETOR toroid preamp
Couldn´t resist to build an preamp for the toroid poweramps. Very simple and minimalistic. The chassi is less than 5"*5"*1,5"! It will be fed by 12V and contains a 12-210V RECOM DC/DC converter(black can on top). I will try with a pair of 1,6VA Talema 115+115:18+18V toroids to get close to 5:1 in parafeed.
Brgds
Lars
Old 17th October 2008, 01:06 PM   #2
I assume you know already what happens
if you were to lift C2 halfway up into R2?
Old 17th October 2008, 01:14 PM   #3
revintage's Avatar
You would sabotage the parafeed circuit?
Brgds
Lars
Old 17th October 2008, 01:44 PM   #4
Default ultrapath ...
Hi revintage,
I think you should say "ultrapath".
From Radio News Feb. 1930: “A condenser, C... ,
is needed to form a local signal circuit in the output circuit ...”
BTW: You did the same mistake Broskie did.
( The input should be cathode referred.)
Kind regards,
Darius
Old 17th October 2008, 04:00 PM   #5
revintage's Avatar
Hello Darius,
And you did a mistake participating in this thread. Make your own thread if you want to discuss Ultrapath/Parafeed! Not here please!
Brgds
Lars
Old 17th October 2008, 04:12 PM   #6
Michael Koster's Avatar
You get a balanced-current series push-pull output?
Clever.. maybe not quite 1/2 but offset by 1/Gfs...
Lars:
That's awfully cute. It would go with what I'm building
right now. I assume you'll buff the box to a nice luster.
How did you find that Recom converter? I'm using a stack
of +/-15V for B+ because I didn't know they made any HV
outputs. It's not easy to find on their website.
How do you plan to mount the converter? One method I use
is solder it to a rectangle of veroboard, etc.. larger in one
dimension and screw that down to the chassis inverted so
the converter is in contact with the chassis as a heatsink.
The little bricks like a lot of cooling.
Michael
Old 17th October 2008, 04:50 PM   #7
Default #3
Originally posted #3 by revintage
Hi Lars
No, of course not. It'll still be parafeed.
Kind regards,
Darius
Old 17th October 2008, 06:30 PM   #8
Ultrapath bypasses cathode to low impedance B+, and may have
PSRR issues with a ground referenced drive. Unless you are clever
(as oldeurope sometimes is) and drive with careful consideration
for how this problem may be turned to an advantage. He knows
some very good tricks along those lines.
But here we do not have an ultrapath to B+. We have parafeed
from a triode ref'd close to GND, and high impedance - ripple free
- constant current sink on top.
I don't see how driving common to top or bottom of cathode
resistor in this topology makes for a hill of beans either way?
Everything below the current sink is GND ref'd, and therefore
common noise.
Yes, tapping R2 halfway up will totally "Ruin Parafeed".
Don't ever try that. We don't want anything extra for free.
Old 18th October 2008, 08:00 AM   #9
Default you should know that...
Hello Forum,
...parafeed is just the short form for parallel feed.
The opposite is serial feed.
In a serial feed (Abb.77)circuit the load in in the DC path.
In a parallel feed (Abb.76) the load is DC free.
That's it, nothing mythical in there.
See attachment,
parallel-feed = Parallel-Speisung
serial-feed= Serien-Speisung
Kind regards,
Darius
Old 19th October 2008, 10:35 AM   #10
Default #8
Originally #8 posted by kenpeter
common noise.
Hello kenpeter,
you are right, I had Broskie's in my mind.
To answer your question, please have a look there:
http://www.nutshellhifi.com/library/Tube_Fest_Talk.html
Lars is making something equal to the Western Electric (output).
The problem is that the current source is imperfect and the
output transformer adds an unknown impedance to the anode.
This generates a 'noise' current in the cathode resistor and adds its 'noise' voltage drop to the input.
This problem is solved by referring the input to cathode, see Western Electric (repeater amplifier).
The LED in Lars's circuit has a low impedance and makes the cathode ground referred. But what about R4?
Kind regards,
Darius
Building a preamp - somewhat new to tubes jscherer Tubes / Valves 3 19th February 2009 03:21 AM
Building a Preamp ray bronk Tubes / Valves 11 22nd June 2008 03:51 PM
Building a high quality gainclone toroid coupling transformer with "tubeness" winding ionomolo Chip Amps 16 13th February 2008 01:20 PM
Help: Toroid choke for a preamp Irakli Tubes / Valves 7 20th December 2005 12:30 AM
Building a audio preamp G4ME Solid State 1 25th January 2005 03:36 PM
Page generated in 0.82030 seconds (11.11% PHP - 88.89% MySQL) with 11 queries
