I want to start buiding a PP amp using one of those tubes. I already have two OTP having 2300 turns in primary (plate-to-plate, center taped) and 90+45+45 turns in secondary.
Using the 90 turns secondary with 8ohm speaker, I will have around 5200 ohm plate-to-plate load. Looking to all schematics found for those tubes, that load seems too low. is it possible to use that OTP, and what would be disadvantages of using it?
p.s. power transformer has 300V in secondary.
Thank you
Dragos
Thank you
Dragos
azazello said:How square surface is the Your transformers ? This is begin to calculate Your Transformer! If You want 10-20 wats per channel, Your
transformer must be equivalent to 100-200 W AC power! Or 12-15-18
sq. sm of coil!
The transformer has around 8 square cm in section.
kuroguy said:I'm sure someone will correct me if I'm wrong. I believe GU-32 is equal to 832. The 832 PP amp likes about 8.5K transformers.
I know tha 832 PP amp likes 8.5k transformers. My question was: what are the effects of using my 5.2 k transformers with 832 tube
? Would be that transformer more suitable for 829 PP amplifier?
Yes it's equivalent to a 832.
GI-30 is odd though, intended for HF pulse stuff.. low dissipation iirc.
If you don't change the operating point, and just the iron to a lower load, generally, power is up, distortion is up.
5k sounds about right for GU-29, as it's basically a pair of 6L6's, and that's near what they like...
I know tha 832 PP amp likes 8.5k transformers. My question was: what are the effects of using my 5.2 k transformers with 832 tube ? Would be that transformer more suitable for 829 PP amplifier?
You may want to check this thread - I've run some numbers for 829B PP AB1 at various plate voltages:
http://www.diyaudio.com/forums/showthread.php?s=&threadid=130939&pagenumber=2
I couldn't resist grabbing a pair of RCA 829B from ebay for the looks alone so this is my current project.
- Tubes / Valves
- GU-32/GI-30 tube PP amp
