| diyAudio Sponsor | ||
#11 |
azazello
From 6V6 pin five (grid?) its a resistor 1k ohm then a capacitor RUBY .1M600 (orange drop) that connects to 6N1P. The resistor measures ok, but it looks like its "leg" has been hot. |
#12 | |
imposible.....Please, unconnect the primary wire of another output transf. from plate /an./ of good tube and connect it to the plate /an./of "bad tube" for somme seconds and mesure 12 v. on res. 174 ohm. If there a sound? The filement of ECC82 is diferent |
#13 |
I got help from a friend with a ossiloscope and the amp is now playing on both channels!
Thanks all for your input and help! |
| Trouble in a new DIY amp. | andRookie | Tubes / Valves | 33 | 7th May 2007 09:04 AM |
| DH 220 trouble | jmgreenlee | Solid State | 11 | 8th April 2007 07:25 PM |
| trouble | Sherkhan | Chip Amps | 1 | 12th July 2004 02:41 PM |
| Page generated in 0.07096 seconds (72.00% PHP - 28.00% MySQL) with 11 queries |
