| diyAudio Sponsor | ||
I'm working on a tube microphone preamplifier where input tube is EF86/6267. I find this tubes quite noisy, some of them are ok from beginning but later become noisy. I could simply change the tube, but prices are quite high and many new tubes are noisy from beginning. Since i love the sound of EF86 input stages i would really like to change this tube with another sharp cutoff pentode tube. I can get SQ, gold pin E180F or normal version of EF184. Both are about 5 times cheaper than EF86 and stock is almost unlimited. Schematic of preamplifier i'm working on is here: http://img56.photobucket.com/albums/...raf/REDD47.gif Input stage looks exactly like example for AF amp in Philips datasheet for EF86, but i can't find nothing similar for E180F. So, what should i do to replace EF86 with E180F? I compared some values and E180F have higher Ia, Gm, Mu and lower Ri. I guess i have to change Ra, Rk, Rg2. If you look at schematic of mic pre there is 330k resistor which loads EF86. Does it remain the same for E180F? Yeah, many questions. I would be very happy if anyone tells me how to start so i can experiment. Btw, anyone have experiences in replacing this two tubes? Regards from Miha |
#2 | |
How about D3A, the German Post Office Pentode? You can get these on eBay for about $11 each last time I checked. (U.S. types like 7788 and 6688 might be worth a look as well.) Yes you will need to figure out the optimum operating points for any tube you substitute.. These high transconductance types all run at very high currents compared to EF86, but are much quieter. New plate, screen, cathode resistor values will be required..
www.kta-hifi.net |
#3 | |
6688 is E180F and D3A is EF184.. I can get this tubes for 2,5 euros or even cheaper. I would like to focus on E180F/6688 because i can get SQ version for same price. Miha |
#4 |
6J32P, 6J52P, 6J53P
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#5 | |
www.kta-hifi.net |
#6 | |
Miha |
#7 |
D3A is no way an EF184! D3A is a supertube by all means with no substitute! Only some Russian tubes are close but very inconsistent in performance.
e180f can also be substituted by 6J9p(which is excellent sounding and avalable). P.S I love e180f sound! too bad I only have 2 Is there any spare one I can get from you as I am using these in my favorite SE pre? |
#8 |
Thanks for informing me about D3A. About the E180F; i can get you some if you want, send me PM.
Miha |
#9 |
E80F should work in most circuits as drop-in for ef86; this might be exactly what you're looking for.
Simon |
#10 | |
The "guy" knows them all well. Enjoy!
| Help with e180f and ixys current reg | duderduderini | Tubes / Valves | 4 | 20th February 2008 12:51 AM |
| 6688/E180F line stage? | pengboon | Tubes / Valves | 26 | 7th August 2007 04:39 AM |
| EF86 Gm | dsavitsk | Tubes / Valves | 7 | 31st March 2007 07:59 PM |
| E180F triode-strapped. | jim | Tubes / Valves | 15 | 16th September 2003 11:00 AM |
| Page generated in 0.12071 seconds (82.17% PHP - 17.83% MySQL) with 10 queries |
