| diyAudio Sponsor | ||
I'm trying to locate a vendor in europe that stocks the meshplate TJ 300B tubes with 2.5V heaters. Any suggestions? I've tried google but can onlty find 5V heater types. Failing within europe, I guess someone in the States will be the next option. I already tried DIYhifisupply, but they only have the 5V version in stock. regards Raja |
#2 | |
Sophia Electric here sells TJ made tubes (some are custom versions only available from Sophia) under their own label and currently list the tube you are looking for as available: http://www.sophiaelectric.com/pages/se/300B2.5v.htm I would also suggest you take a look at the JJ 2A3 which is really a 300B with a 2.5V filament. (40W plate dissipation rating, and otherwise identical to the JJ 300B) I'm using a couple of older pairs of JJ 300B in my amplifiers (late 2000 vintage) and they work and sound good. The TJ 300B meshplate also sounds very good, but I have not heard these in my own amplifiers, and I have not heard the 2.5V version either.
www.kta-hifi.net |
#3 |
Thx Kevin, i'll try direct then.
regards Raja |
#4 |
surfing the 2nd harmonic ... @@@@ |
#5 |
Thx for the link. I ordered last night from Sophia direct, but it's nice to know there may be another source too.
regards Raja |
#6 |
You're welcome
Did you already have a set and you are looking for replacement ? Or are you trying something new ? Either way, let me how you like the TJ 300B.
#7 |
It's something completely new to me. I managed to get ahold of an ex diyers amp that needed the tubes. It has a 3.5K primary opt and 2.5V filament supply. So the 300B 2.5V seems suited for the application over anything else.
Sophia had ran out of the globe mesh versions that I requested. They made a mistake assuming they had them in stock. They were very good about it though and upgraded me to the st princess version at no additonal cost. regards Raja |
| MachMat or Tentlabs Heater Supply for 300B | eeyore | Tubes / Valves | 6 | 4th July 2007 01:34 PM |
| peak current 300B heater with start up | Jaap | Tubes / Valves | 12 | 6th June 2007 12:47 AM |
| SMPS for 300B heater ? | Jaap | Tubes / Valves | 9 | 25th August 2005 12:49 AM |
| 300B mesh plate, 2,5 Volt Heater | reinhard | Tubes / Valves | 6 | 2nd September 2002 01:54 PM |
| Page generated in 0.08115 seconds (81.87% PHP - 18.13% MySQL) with 10 queries |
