diyAudio Sponsor
Old 8th October 2008, 07:06 AM   #1
dsavitsk's Avatar
Default Cap to bypass bias battery
I am using 2x 9V batteries in series to bias the grid of a tube to 18V. Should I bypass the batteries with a capacitor, and if so, what value would people recommend?
http://www.ecpaudio.com
Old 8th October 2008, 05:00 PM   #2
kevinkr's Avatar
Default Re: Cap to bypass bias battery
I usually use something in the range of a few uF, to avoid cap leakage currents from running the batteries down I generally use low voltage films for this. It may take a combination of several caps in parallel to achieve the best results..
www.kta-hifi.net
Old 8th October 2008, 08:21 PM   #3
Gluca is offline Gluca  Italy
tarmac ripper
Gluca's Avatar
well my experience is that I don't need any cap ... but I am deaf. I tried many caps (type and value) but couldn't notice any difference
OH! Me too, I am using 2x9V to bias 211's.
Gianluca
Old 8th October 2008, 08:38 PM   #4
bigwill is offline bigwill  United Kingdom
I would personally put a resistor in series with the battery (outside of the loop of the transformer and load resistor)
So then it just becomes a high impedance biasing source
Old 24th February 2011, 11:00 AM   #5
Speaking of battery bias. This schematic which comes from the site of Troels Gravesen uses a battery in series with the grid. I have also seen this type of bias arrangement in a linestage or phonostage from an American company.
What are the voltage requirements of the cap that bypasses the battery?
Is it full B+, only a few volts, or...?
Thanx!
Esl Battery Bias JonasKarud Planars & Exotics 12 22nd May 2008 06:13 AM
Stray hum pickup *preamp* cathode R-bias vs. battery bias & 12AU7vs.5687 awedio Tubes / Valves 2 19th April 2008 01:30 AM
Battery grid bias to fixed bias in Toccato? w00t Tubes / Valves 3 2nd December 2007 12:34 AM
Grid battery bias on phono.... fred76 Tubes / Valves 16 10th September 2005 09:24 AM
Battery bias? Bas Horneman Tubes / Valves 53 14th February 2003 09:54 AM
Page generated in 0.07919 seconds (77.07% PHP - 22.93% MySQL) with 11 queries
