diyAudio Sponsor
Old 8th October 2008, 03:09 AM   #1
diaz028 is offline diaz028  Canada
Default Preamp Voltages
I have an amp design that I want to convert from 6L6 50watts to EL84 ~20WAtts. I want to use a smaller transformer maybe 300-0-300.
The original design calls for 360-0-360 and feeds the preamp at about 390V. What happens if I feed it about 300V?
Will it increase or decrease the gain? Will it color the tone? What should I expect?
Thanks!
-D
Old 8th October 2008, 03:39 AM   #2
aardvarkash10's Avatar
Default back ot first principles
figure out what voltage swing you need to the EL84 cf the 6L6. DO the hard yards on the pre-amp tube's loadline. You'll learn heaps!!!
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012
Old 8th October 2008, 03:49 AM   #3
Default Re: back ot first principles
What is the hard yards on the preamp tubes?
Voltage swing? You mean DC voltage?
-D
Old 8th October 2008, 04:00 AM   #4
Default hi diaz
you need to know the specs of the driver tube. From that and the specs of the EL84 (needs around 12v p-p swing to drive to full output as I recall) you can figure out what voltage you will need to drive the whole system. Just changing the supply voltage and plugging in a couple of EL84's is a path to unpredictable results... A schematic would be helpful in the first instance.
Strange: Preamp Xformer Overheating but Not Blowing Fuse and Supplying Right Voltages dtm1962 Parts 4 29th January 2008 12:18 AM
ARC SP9 Preamp voltages topfee Tubes / Valves 8 8th January 2008 02:53 PM
voltages for project 88 preamp oldfatbubba Chip Amps 3 15th August 2007 09:31 PM
ESL voltages Fanuc Planars & Exotics 5 11th February 2006 07:36 PM
PSU cap voltages lawbadman Solid State 4 3rd January 2004 12:37 PM
Page generated in 0.07685 seconds (73.74% PHP - 26.26% MySQL) with 10 queries
