| diyAudio Sponsor | ||
12ax7 series is this correct??
just wondering if this tube circuit is right |
#2 |
Looking at it quickly, the B+ voltage should be 100V or more, not 10V
R1= R5 so the bias voltage is equal accross both. Otherwise looks good. Doug
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well) Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus |
#3 |
thxs why when change the volts form 10 to 100 get the same out
amount of ac out?// should pins 6 7 8 be on top or bottom??? |
#4 |
I'm not sure if the 12AX7 is terribly linear at 10V. I would also suggest
a higher plate voltage. It doesn't matter if section one (pins 1,2,3) or section two (pins 6,7,8) are on top. Just be sure to observe the cathode-to-heater ratings. |
#5 | |
The 12AX7A is not linear at 10V at all, in fact the minimum circuit supply voltage for reasonably linear operation with a 12AX7A based mu follower like this is around 200V. The models don't always provide an accurate portrayal of operation at very low voltages. A 6GM8 operating at around 24V - 36V would work much better if low voltage operation is required, however gain will be only about 14 (23dB) as opposed to nearly 100 (40dB) with the 12AX7A best case. One other thing to be aware of is the need not to exceed the filament to cathode insulation rating in the upper triode with higher voltage operation than about 200V.. (Use filament supplies biased to a value about midway between the voltages of the lower and upper cathodes - do not exceed the maximum voltage differential to either!)
www.kta-hifi.net |
| AE TD series parameters - which is correct...? | Defo | Multi-Way | 3 | 6th July 2009 11:55 PM |
| Three 10" 4Ohm subs, wired in series or series-parallel? | Nagamitsu | Car Audio | 24 | 10th May 2009 03:24 AM |
| Yamaha CA-series / CT-series parts | DragonMaster | Parts | 9 | 19th January 2007 07:48 PM |
| My PCB for DoZ, it correct? | mod_evil | Solid State | 4 | 4th October 2005 01:30 PM |
| Quality of Hammond 300 series power transformers compared to 200 series? | G | Tubes / Valves | 8 | 21st September 2003 02:27 PM |
| Page generated in 0.08251 seconds (71.05% PHP - 28.95% MySQL) with 11 queries |
