| diyAudio Sponsor | ||
I read a good thread here on sizing coupling caps on this forum but I didn't completely follow it and I think I need a little guidance.
I have a newly aquired Magnavox 175 amp. It has a pair of 12AX7 phase inverters and four 6V6 in push pull stereo. I think the coupling caps have some room for improvement. The input caps between the RCA jacks and the 12 AX7 grid are .007 uf ceramic disk in series with a 47K resistor. I have a handfull of .47uf vitamin Qs that could be used for this. Is that too much capacitance for this application? Between the 12 AX7 plates and the 6V6 grids are .047uf caps. How about using the 0.47 vitamin Qs here too? Link to Schematic Thanks |
#2 |
In some designs it is important to have the coupling poles placed higher in frequency than the power-supply decoupling poles. Otherwise low frequency oscillations occur due to positive feedback through the plate power supply.
However, in some designs, the feedback on the plate supply line will be negative so the amp will remain stable if the coupling pole is placed lower than the decoupling. If you up the interstage coupling cap values in that amp it will be a coin toss if there will be low frequency oscillations because of that odd-ball phase splitter(when you consider part and tube variation). If you do get oscillation, adjusting R10 and R21 should stabilize it. If you want to upgrade the interstage caps in that guy without doing further tweaking, I'd probably play it safe and use ones of equal value but higher quality. You can use .47uF for the input cap in any case though, since it is not in between stages. It will be larger than necessary, but it won't hurt anything. |
#3 |
Link doesn't work. ceramic sucks.
1/2piRC |
#4 |
When low frequency oscillation is not a threat, I generally go by this rule of thumb Keep R x C = .1
1uF for 100k so when resistance doubles, capacitance will half .5uF for 200k (.47uF close enough) when resistance halves, capacitance will double 2uF for 50k (2.2uF close enough) Some people would consider my choice of cap on the large side, but I consider keeping a close to flat phase response as important as flat amplitude. Phase will shift before amplitude begins to fall. When using negative feedback you can go smaller on the capacitors that are in the loop and get the same results. Since feedback helps correct the phase difference. |
#5 | ||
Bottom line: go ahead use your .47uF vitamin Q's for the 12ax7 input. For the rest of the coupling caps, keep them the same as schematic values if you want to play it safe. Upgrading quality is ok, as long as the values are the same. Quote:
#6 |
Thanks for your comments Jeb, they are very helpful. I'm a rookie so bear with me here.
As for the first caps (non-interstage), if a guy had let's say 2 a .047uf and a .47uf of identical construction and quality, wouldn't the larger be the choice? Are there cons? Is the gain effected by the cap value (RxC)? And why would we want to calculate the -3 dB point? In the equation, what is it that equals (1/2 pi RC)? Is this the answer to my question above about gain? As for the interstage caps, I have a hand full of .047 orange caps that I can change out for the interstage. I just don't trust the old oil/paper caps not to catch fire. I have also used Sonicaps in crossover networks with audible (to my ears) results. Now I know this is a hot topic, but if a guy wanted to experiment (compare the $1 orange drops to the $5 Sonicaps) , would this be an appropriate application for the Sonicaps? Thanks |
#7 |
The coupling cap in conjunction with the next stages input impedance form a high-pass filter. This blocks DC and frequencies below a certain point, but will allow frequencies above a certain point to pass. Since the blocking is gradual with frequency and not absolute, they developed a point to use as reference. This point is the -3dB point and is referred to as the cutoff frequency, which is the frequency at which the amplitude is attenuated by 3dB.
http://en.wikipedia.org/wiki/High-pass_filter Example frequency response of high-pass ![]() Cap size does not do anything to the gain above the point where it begins to roll off. The cap size will just change the point at which it begins to roll off. |
#8 | ||
#9 |
OK, I get it. But I do have another question or two.
I now understand that a consideration in monkeying around with cap values in this situation is that one will alter the cutoff frequency, much like a high pass filter in a crossover network. I ran the calculation on this application of the existing .007 uf cap (measured value) with the 470 K resistor in parallel and came up with 48 hz, a credible choice. However the drawing calls for a 1000mmf which I interpret to be 1000pf or 10(-6) resulting in a 338hz cutoff which would seem a poor choice, unless you have a problem with turntable rumble to deal with. At any rate, it would seem that using the larger caps (.47uf) will drop the cuttoff frequency to less than 1 hz thus for all intents and purposes eliminating the filter entirely. Since I'm not running a cheesy turntable, perhaps that's no big deal. I could drop the resistance value to 10K to bring up the cutoff, but that would create an impedance problem for the source. And there may be more to this than I gleen. You did say "in conjunction with the next stages input impedance" but the next stages impedance would seem to be to be in series not parallel. Is that not correct? What am I missing here? I do have to consider all of the parallel resistance, not just from that one resistor, correct? And I was refering to Orange Drop caps. I type faster than I think. And I will scope the source and see if I can listen to it with the cap bypassed. That will be revealing. |
#10 |
1mmF is 1milli milli Farad =1uF
1uuF is 1 micro micro Farad= 1pF. 1000pF=10^-9F=1nF
regards Andrew T. |
| Why did Marantz use 4 capacitors for coupling? | bleachershane | Digital Source | 4 | 5th April 2009 11:04 PM |
| Need small coupling capacitors | pandaemonium9 | Solid State | 4 | 13th November 2006 06:51 PM |
| Sizing capacitors | preiter | Power Supplies | 5 | 29th May 2006 04:48 AM |
| AC coupling capacitors... | Frazzled | Solid State | 8 | 30th June 2004 06:28 AM |
| BOZ coupling capacitors .1 and 10.0 microF | JC Fardo | Pass Labs | 0 | 18th November 2003 10:44 AM |
| Page generated in 0.11853 seconds (81.65% PHP - 18.35% MySQL) with 10 queries |
