diyAudio Sponsor
Old 4th October 2008, 03:26 PM   #1
Default Unsolved problem EL34/12AT7/5AR4
Hi guys,
(I'm a real newbie, so please be indulgent with me )
Someone gave me a SE EL34/12A*7/5AR4 amp.
It sounds quite good but one channel is louder than the other, particularly in the mid-range.
I swapped tubes, swapped and changed the 12A*7; the only one I didn't change is the rectifier.
I interchanged my speakers; I tried the amp with another pair of speakers. I swapped wires and changed them.
I checked soldering, resistors and caps. Everything seems OK. But obviously, there is something wrong. Because one channel is always louder than the other.
The next step I should do is checking transfos. Gosh. I'm not really sure what to do about that...
Before this step, do you think I could do something else, that is obvious for an old DIY pro but unevident for a rookie ?
I know I should have done the schematic, but I didn't
Thanks a lot
Old 4th October 2008, 07:55 PM   #2
TubeHead Johnny's Avatar
How old is the amp? Sounds to me like a resistor or cap has drifted in value, making the channels sound uneven.
Do you have knowledge working with high voltage electronics? If not get a qualified tech to check it out. Voltages inside an amp are deadly!
bad 5ar4? sturmj Tubes / Valves 2 11th February 2009 07:09 PM
Funny bias problem in PP EL34. Please help OzMikeH Tubes / Valves 9 14th July 2008 10:22 PM
Tubes for Sale - Link to List 12AX7,5AR4,6550,EL34 and More baileyler Vendor's Bazaar 3 22nd April 2008 01:20 PM
a 5ar4 problem contaxchen Tubes / Valves 23 17th February 2005 12:00 AM
Page generated in 0.07926 seconds (70.28% PHP - 29.72% MySQL) with 10 queries
