Where do you put the standby switch - Page 2 - diyAudio
Old 4th October 2008, 02:05 AM   #11
I have used standby switches in the CT since the 60's, in guitar amps.
However there are some precautions. Definitely use a snubber. Remember that in the open position, the switch sees the full standoff voltage of the secondary so make sure you use a heavy duty switch.
First saw this on old Fender amps.
The most you can usually get are 240v/10A for a standard toggle switch. They can handle it, but it isn't exactly EC or UL approved! To say the least. I have had these start to leak voltage before. Not good.
The relay that was mentioned is only rated at 240v so it may not survive the experience either.
Now, when I have to do this and it is for anybody but myself, I use a HV vacuum relay. These babies can take it all and then some, but will cost you dearly. Check out gigavac. I forget the model I use but can dig it up if interested. I think these set me back about $40US.
Old 4th October 2008, 05:00 AM   #12
Default Yes Funkytek I am interested
Hi
I would like to get some for some other projects anyway so yes i would love it if you could dig up the info. If you could let me know how you rig it up (do yo use a snubber as well?)
I would be doubly appreciative
Nick
"Better to say nothing and keep them guessing than to speak and remove all doubt."
Old 4th October 2008, 05:31 AM   #13
ashok's Avatar
Default MOSFET switch ?
How about a series MOSFET after rectification and switch that on and off ?
AM
Old 4th October 2008, 04:39 PM   #14
SpreadSpectrum's Avatar
Hey, you could use the MOSFET as a regulator, too making a very smooth supply. HV MOSFETS are easy to come by and cheap compared to relays. You'd have to have some volts to spare to use this approach, though.
standby switch 9am53 Tubes / Valves 17 25th October 2010 12:24 PM
Standby Switch dre7 Tubes / Valves 6 18th October 2007 08:07 AM
Standby switch elementx Tubes / Valves 6 24th January 2006 03:46 PM
Standby switch for Quad II? Zombie Tubes / Valves 13 13th March 2003 11:20 AM
Copyright 1999-2017 diyAudio
