| diyAudio Sponsor | ||
Looking at this tube, it's mu is 78, rp is 5400R. It would be a great candidate for a preamp using a trafo, say with 12:1 step down, giving overall gain around 6, 15.5dB. This should give a Zout around 40R, which would give it terrific drive. The only downside would be overload margin, probably not much better than 3Vpp.
Has anyone used this tube, could I ask your experience of the best operating voltages and currents for nicest sound? Cheers, Hugh |
#2 |
bump??
#3 |
Try to get in touch with Eric Kingsbury aka Poinz of AudioTropic. He uses the 6GK5 in his amp designs in a diff pair/driver. I have tried it driving an IT and was less than impressed but I didn't play around with operating points.
#4 |
Thanks Jazzbo,
Will speak to Eric. Any others want to offer comment? |
#5 |
The 6GK5 is a frame grid, gain controlled triode designed for use as a VHF RF amplifier.
Be sure your foil hat has a good low impedance ground. |
#6 |
diyAudio Moderator Emeritus
Gary Pimm uses them in his phono stage. 2,5mA or current running through it.
http://www.pacifier.com/~gpimm/phono.htm |
#7 |
Hugh,
I just put together a little SET amp using the 6GK5 to drive a 1626. The 6GK5 is battery biased (Nimh) at about 1.3vg/6ma and the 1626 @ 23v/23ma. I needed the gain up front because my signal source is only 200mv (old computer CD drive line out) So far I'm liking it a lot. robert |
| Calculating operating point of a DHT | Pyre | Tubes / Valves | 2 | 26th February 2009 11:09 PM |
| SE amp: Please suggest a better operating point | zobsky | Tubes / Valves | 34 | 21st September 2008 01:00 AM |
| Best Operating point for a 2A3? | sgerus | Tubes / Valves | 10 | 2nd August 2006 01:31 AM |
| 6GM8 Operating Point | ALBQ | Tubes / Valves | 2 | 23rd November 2004 03:45 AM |
| Best operating point for 7044 and 5687 | kooltubes | Tubes / Valves | 7 | 28th October 2004 02:01 PM |
| Page generated in 0.09206 seconds (73.56% PHP - 26.44% MySQL) with 10 queries |
