ESLDD with "anti-triode"
Old 2nd October 2008, 04:35 PM   #21
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Originally posted by revintage
As I understand it Wavebourns proposal is not so much for regulation as ut for reducing ripple with a MOSFET gyrator.
No, I used SS gyrators to load triodes, it is a different story; what I propose now, a R-C filter with big time constant and a source follower.
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Old 2nd October 2008, 05:09 PM   #22
revintage is offline revintage
Sorry Wavebourn, the dumb Swede used the wrong expression .
Still your intention was not regulation, but ripple reduction, or?
You never reported anything about the Alligtor working or not?
Old 2nd October 2008, 05:16 PM   #23
Wavebourn's Avatar
...or effective ripple reduction.
Vgs will be almost constant causing almost constant 3V Vds enough for ripple reduction, while power loss will be very small, and it will work equally well no matter how big or small is a voltage in the power outlet.
Old 2nd October 2008, 05:48 PM   #24
Michael Koster is offline Michael Koster  United States
Michael Koster's Avatar
I think I get it now; filter the gate voltage and the source will follow.
Michael
Old 2nd October 2008, 06:51 PM   #25
kenpeter is offline kenpeter  United States
Wavbourn had posted a servo'd current sink/load. Some time
ago, not too recently. I can't seem to find the darn drawing of
it now. If you can find, or repost the circuit I am referring to?
Do you think there is any way to make an anti-triode of it?
Old 2nd October 2008, 07:34 PM   #26
Wavebourn's Avatar
It was an ordinary gyrator, to avoid a choke and it's artifacts:
Old 4th October 2008, 08:24 PM   #27
boiss is offline boiss  Italy
Hi Revintage,
this has put the cat among the pigeons in that it was always possible to build an SE amp within the esl as a whole using a single tube driving the diaphram. Safety was not an issue with the amp being a part of the speaker. obviously, imho there is no need for the current compensating circuitry provided by the pentode, being there only to balance the DC in the O/P tranny.
Mike.
Old 4th October 2008, 08:37 PM   #28
Because when actively anti-triode bridged so,
twice the power with very little loss of "single
endedness".
Its function is not limited to balancing out DC.
ESLDD with "anti-triode"Hide this!Advertise here!
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
"Bevois Valley" in triode, what to do with the feedback? pwan Tubes / Valves 1 24th April 2009 05:58 PM
JFET "triode-mode" measurements bogdan_borko Solid State 3 8th October 2007 11:08 AM
Triode "Champ" transformer v Edcor dsavitsk Tubes / Valves 13 18th April 2007 11:49 PM
FS: Homebuilt "Aikido" 2A3 single ended triode amp jim_vt Swap Meet 11 21st January 2006 03:38 PM
