Bias supply idea - Page 2 - diyAudio
Old 1st October 2008, 09:30 PM   #11
Geek's Avatar
Originally posted by andyjevans
What's the problem in case of failure?
If the input resistor dies, you lose bias and the output tubes die. Use a wirewound resistor here for reliability.
If the zener fails, the tubes get full negative and cutoff.
Don't use cheap bias pots, use wirewound here too (a 1W-5W wirewound is cheaper than a 1/2W DC rated carbon).
Cheers!
Old 1st October 2008, 10:37 PM   #12
astouffer's Avatar
Are those small blue multi turn pots any good? Because thats what I planned on using The screen supply will be regulated using this schematic http://www.antiquewireless.org/otb/resto0504.htm
I probably will end up using separate transformer to run the relays and other control circuits anyhow. As of right now my plan is to use a quad comparator monitoring each 10 ohm cathode resistor. If any tube goes over the limit it makes an input to the PIC chip go high which shuts off the B+ relay and lights an LED.
Old 2nd October 2008, 02:23 AM   #13
Geek's Avatar
The Bourns ones I've used, yes. They are either WW, conductive plastic (3/4W+) or DC rated carbons (<=1/2W).
Just tie the wiper so that if it opens, the tubes see greater -V than ground.
Cheers!
Old 2nd October 2008, 02:35 AM   #14
kevinkr's Avatar
I recommend the hot molded carbon, hermetically sealed, 2W Clarostat, Bourns, or Ohmite or similar RV4LAYSA locking style pots - in over 20yrs these have never let me down, and I've had old tube Marantz and other hifi gear that used these and so far I've yet to see a bad one, they just seem to last forever. I think the Clarostats are available either at Mouser or Digikey - Digikey's prices are a lot better on these however.
Use a 100K resistor between the wiper and the hot end for insurance in the event that the pot wiper ever goes open. (I don't bother, but frankly I do know better, do as I say, not as I do.. )
Regulated screens with regulated bias should be the cat's meow, but for even better stability replace that zener (which will drift a bit as it warms up) with a low cost precision voltage regulator..
Also add a resistor from the bottom end of the pot in series to ground so that you cannot adjust the pot to 0 bias, preventing some serious mishaps. Multi-turn pots are very fiddly and the resolution is not required.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 2nd October 2008, 03:55 AM   #15
Tubelab_com's Avatar
Zener goes open and you end up with more than -50V across that cap..... If the zener fails, the tubes get full negative and cutoff.
My experience (I have blown up a lot of parts) says that zeners usually fail to a short, unless a bunch of current was available to blow it open.
The point about regulating the bias without regulating the plate (triode) or screen (pentode) is very valid. I use a similar design in the Tubelab SE without the zener. I use a resistive divider which does waste some energy but works well.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 2nd October 2008, 04:12 AM   #16
kevinkr's Avatar
Usually my experience too, and of course the short scenario is worse for the output tubes than the reverse situation, but operated well within ratings neither scenario is very likely after the first few hours of operation. My most memorable problem with a zener was actually an open, and yeah the cap across it blew up.. Never happened since..
Using LED bias for 4.5 mA cathode current, is it a good idea? rtsang Tubes / Valves 11 29th January 2009 04:53 PM
idea for a simple bias servo for AB PP vladn Tubes / Valves 27 20th October 2008 03:32 AM
Power supply idea KBK Pass Labs 33 20th November 2006 06:38 PM
new idea of DHT heater supply kekso22 Tubes / Valves 25 15th March 2005 11:07 PM
EE-Zee & Chee-Zee bias and offset adjustment idea thoriated Tubes / Valves 0 3rd April 2004 12:16 AM
Copyright 1999-2017 diyAudio
