diyAudio Sponsor
Old 29th March 2003, 01:53 AM   #1
Default Tube life question
I am thinking of building a OTL amp. My question is how long
can I expect a 6as7ga to live if asked to handel 100 ma at 100v.
Or how much longer would it live if asked to only handel 70 ma at
100v?
bob12345678
Old 29th March 2003, 02:07 AM   #2
diyAudio Senior Member
fdegrove's Avatar
Default I AM BAD.
Does starving yourself to death help?
Frank
Old 29th March 2003, 02:36 AM   #3
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Try one at 300mA, 200V. After that one goes, try stepping down the voltage and/or current a little and try again... After that one goes......
Tim
Old 29th March 2003, 03:47 AM   #4
Brett's Avatar
Steve Bench has a report on his site where he's tallied lots of data and related it to the type of filament and their power, versus the cathode current. Not definitive, but gives an idea.
http://members.aol.com/sbench/heater.html
Old 29th March 2003, 04:43 AM   #5
Sch3mat1c's Avatar
Someone here should conduct a test. Grab a box of say, 12AU7s, 6V6s, 6L6s, a type of sweep tube, and some 6080s or 6AS7s and see how long they last for each rating.
Unfortunately, this could take a *long* time to get the data.
BTW, I heard that unipotential coated cathodes can do like, 200mA/W at saturation. So in theory, a 6CD6 could pull 3 amperes of cathode current! Of course, screen and grid voltages would have to be through the roof...
Tim
Old 29th March 2003, 06:20 AM   #6
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
Default Valves last forever!
Provided that you stay within all the manufacturer's ratings, valves last forever. I say this because DIY amplifiers are generally made obsolete by their owner/builder thinking up a new idea long before the valves wear out.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 30th March 2003, 12:48 AM   #7
fdegrove's Avatar
Default MUCH UNDERRATED...
Proviso: you take the low side, not the hot side of specs.
For instance: run a 12.6 heater at 12 V and just make sure it can draw it's required current which I feel is more important than the voltage rating, never overdo the ratings or you'll see transonductance figures of the tube vannish within a few minutes.
/Forever.
Frank
Old 31st March 2003, 10:23 AM   #8
SHiFTY is offline SHiFTY  New Zealand
SHiFTY's Avatar
Are you saying we're ever so slightly insane?
Old 31st March 2003, 02:10 PM   #9
EC8010's Avatar
Default The men in their CLEAN white coats...
Never. I am sure that we all operate a policy of constant improvement on our products driven by a vigourous research initiative, supported by a vigilant purchasing department, and backed by distaff-led industrial design.
(Translation: I've thought of this great new idea for a valve I couldn't resist on eBay, and I've promised to make it look nicer this time.)
Old 31st March 2003, 02:17 PM   #10
robbie is offline robbie  United Kingdom
robbie's Avatar
Default i so know
where you are coming from..
think its a male 'thang'
tube life bonsai171 Tubes / Valves 20 28th April 2010 09:21 PM
Used Tube Amps, second life.. planet10 Tubes / Valves 24 29th January 2009 04:43 PM
Maximising Tube Life jkeny Tubes / Valves 44 13th September 2008 02:37 AM
best long life for my tube jeapel Tubes / Valves 2 4th May 2005 10:22 PM
Tube Life Glowin Plates Tubes / Valves 14 6th October 2004 06:01 PM
Page generated in 0.10529 seconds (77.42% PHP - 22.58% MySQL) with 10 queries
