| diyAudio Sponsor | ||
Lets say you have a bunch of single triodes, 6J5 for example. You want to match them for use in a CCS driven Differential stage. What would you measure to establish that tube #3 is the matched pair of tube #81?
I assume that the best place to start is to place them in the circuit you plan to use at the intended operating point and measure the voltages across the tubes. How equal is equal? |
#2 |
Actually, if it's a CCS-loaded long tail diff stage, the matching isn't at all critical.
If you do want to match, I'd set up a jig to run the tube at the designed operating point (plate current and grid-to-cathode voltage), then match for plate voltage and gain.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#3 |
Trace curves on transparent films then match them visually.
There was a project related to some geological research. One Russian computer center got an order to calculate percentage of some spots on maps of the entire Earth. Instead of loading the data into the computer a programmer took scissors and cut maps, then weighted results on precision scales. He got a premium for fast and accurate results.
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#4 |
Thanks Sy, that is about what I figured would be the case. Sometimes I ask questions so I can be sure I am as crazy as I think I am, by seeing if someone agrees with me. As far as curve tracing, I remember a few years ago an Italian (I think) company sold a microprocessor controlled curve tracer. I think they stopped making it, I think, is there a similar unit from someone else?
#5 |
[QUOTE]Originally posted by SY
[B]Actually, if it's a CCS-loaded long tail diff stage, the matching isn't at all critical. Is it also possible that in a CCS LTP that one tube, in an extreme example, could draw 15mA and the other 5mA in a circuit set for a total of 20mA? That is why I figured I'd like to match the tubes. |
#6 |
You cam feed your target stage with a sawtooth and save oscillograms to compare.
#7 |
Hi tubesman
For a differential stage with CCS in the tail and matched plate resistors (which are essential conditions for a differential stage anyway) Morgan Jones recommends to match triodes by comparing plate voltages: same voltage = matched. Erik
my surname is indeed 'de Best': neither misspelling nor snobbism! Ask SY! |
#8 | |
#9 | |
#10 | |
| Tube matching service - As found on Craigslist | Sal Brisindi | Tubes / Valves | 1 | 17th December 2007 04:10 AM |
| Tube Matching and Push-Pull | dsavitsk | Tubes / Valves | 2 | 23rd September 2007 12:25 AM |
| Tube Matching | Rob11966 | Tubes / Valves | 11 | 11th September 2007 09:52 PM |
| Tube power Amp matching with SAE Mark M pre amp and AR18 speaker or MS 25i | soultribe | Tubes / Valves | 1 | 13th August 2006 11:08 AM |
| tube matching fixture | Original Burnedfingers | Tubes / Valves | 8 | 1st September 2003 12:01 PM |
| Page generated in 0.10916 seconds (80.97% PHP - 19.03% MySQL) with 10 queries |
