diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   Connection Jensen 4-pole (http://www.diyaudio.com/forums/tubes-valves/130578-connection-jensen-4-pole.html)
lauret 29th September 2008 07:09 PM
Hello,
I have a question about the Jensen 4-pole cap.
Normally I would connect the center tap to the star earth, but doing so with the four pole cap seems not like it's supposed so.
I would like to use the 4-pole after a CL filter. Should I connect transformer to rectifier, then to first C with wire back to CT. Then from first C to L and then from L to input+ of last C (jensen four-pole) and input- to CT back, and output- to star earth?
Hopefully is this understandable... Normally I speak in diagrams...
Thanks, Bart
dsavitsk 29th September 2008 08:14 PM
http://www.partsconnexion.com/jensen/faq1.gif
lauret 29th September 2008 08:19 PM
That doesn't explain anything about star earth. Should you still connect the center tap of the transformer to the star earth using this capacitor?
Jeb-D. 29th September 2008 09:52 PM
Transformer CT to capacitor input -
Capacitor output - , to star earth/audio ground
The transformers CT will be earthed through the capacitor with this configuration. It will maximize the performance of the cap in keeping charge currents out of your audio ground.
lauret 30th September 2008 02:43 PM
Thanks! That explains everything.
Copyright 1999-2017 diyAudio
