diyAudio Sponsor
Old 28th September 2008, 11:45 PM   #1
Default Cathode bias 6LU8 UL/Triode
I have done a lot of searching in order to understand how to choose Rk for desired operating point and I think I can manage it if I have either reasonably accurate mu and rp or plate curves. The problem comes with trying to figure it out without the availability of either one. Specifically WRT tubes like the 6LU8 and 6LR8 compactrons for which I can find no triode or UL curves or even mu/rp data in these modes.
So, has anyone come across the curves for these tubes in triode and UL modes? Is there another method? If one had triode and pentode curves could one extrapolate a reasonable Rk by averaging the Rk results for triode and pentode to get a good UL choice?
mike - www.keepingsundayspecial.org
Changing grid leak bias preamp to cathode bias bereanbill Tubes / Valves 8 28th March 2009 05:26 PM
300B Cathode Feedback + Cathode Bias korneluk Tubes / Valves 13 7th January 2009 08:07 PM
Cathode bias 6LU8 UL/Triode mashaffer Tubes / Valves 2 29th September 2008 10:37 AM
Stray hum pickup *preamp* cathode R-bias vs. battery bias & 12AU7vs.5687 awedio Tubes / Valves 2 19th April 2008 01:30 AM
UL to triode mode conversion on cathode bias amp-different cathode resistors needed? bigwill Tubes / Valves 6 30th December 2007 12:37 AM
Page generated in 0.06356 seconds (65.72% PHP - 34.28% MySQL) with 10 queries
