diyAudio Sponsor
Old 27th September 2008, 05:02 PM   #1
prorms is offline prorms  United States
Send a message via ICQ to prorms
Default need spice model 5814a
Old 27th September 2008, 07:33 PM   #2
Ty_Bower's Avatar
Is the 12AU7 close enough?
Old 28th September 2008, 04:11 PM   #3
kevinkr's Avatar
They are electrically equivalent so I would think so, variations aren't likely to be any worse than that between any two random 12AU7A..
www.kta-hifi.net
Old 29th September 2008, 12:13 AM   #4
wa2ise is offline wa2ise  United States
wa2ise's Avatar
12AU7 spice models are fairly common, and you could test your circuit using different models, and see if the circuit works with all of them. That should give you more confidence that the design is good.
BJT spice model from datasheet - HOW TO? anli Solid State 7 21st June 2011 09:01 AM
Help With 6v6 Spice Model porcatroya Tubes / Valves 0 5th May 2008 06:41 AM
SPICE model Prune Parts 6 16th October 2004 03:22 PM
Spice model doigtee Tubes / Valves 6 12th July 2003 11:42 AM
Spice model for LED? G Solid State 5 14th September 2002 03:33 AM
Page generated in 0.07831 seconds (69.66% PHP - 30.34% MySQL) with 10 queries
