| diyAudio Sponsor | ||
Long ago, I built nifty power amps with glass-enclosed vacuum amplifying elements, esp, with motional feedback bridge circuits. So I collected a bunch of output transformers.
Sitting in my parts box for 40 yrs or so is a Partridge output transformer, a magnificent ultra-linear potted unit with all the windings brought out to pins. Seems to be CFB/0/1.7, 60 watts, about 10 lbs (might be Type P4170/1, not certain). I have a bunch of spec sheets and docs from that period and letter from Partidge, 1967. Bought from Harvey Radio in NYC. Incredible square waves pictured in the spec sheet. Needs a good home. Can anybody tell me if this (once) magnificent unit has much value? Originally sold for $50 which would scale up to thousands today (only kidding). BTW, I'm glad to scan and eMail the spec sheet pages to anybody interested. Thanks for any help.
Dennesen ESL tweets, Dayton-Wright ESL (110-3200Hz), Klipschorn mixed-bass woofer w/param. EQ plus 1954 AR-1W or giant OB HiFi construction since 1956 |
#2 |
well according to ebay completed listings, a similar output transformer (not potted) went for 286 pounds in the UK, about $US500. The description was
Partridge Type W WFB Sought after Partridge Type W WFB/0/1.7ohm. unused judging by the soldered pegs. Top Row AN HT+ HT+ 10-12 kilohms AN then eight sections -connect in parallel for 1.7ohms. Untested , 14cm high , 12cm wide , 13.5cm deep. If that's any help... |
#3 |
Wow. Thanks for checking.
Well, they are truly beautiful units and my guess is that there hasn't been as much advance in the state of the transformer art, at least compared to say, capacitors. Likewise, minimal deterioration over time. Or perhaps that's just wishful thinking. It would be nice to sell among "friends," like here at diyaudio, but hard to beat the opportunities that eBay provides. i also have a Wharfdale 2-way crossover in a painted wood box, potted in wax, at least as old. Looks like an antique to me. Maybe that is worth big bucks on eBay too! Are there any hi-fi museums?
#4 |
Dunno what I was dreaming about, this is not an ultralinear transformer. But it is one of their higher-class units with grain-oriented steel. Those folks sure made fancy units back then. Of course, a British transformer had to be potted against all kinds of tropical weather and insects so it could be used across the empire... back then.
It is made for a 10,000 ohm anode-to-anode load but the primary is brought out to solderable pins as two independent windings for center-tapping With eight secondary windings coming out to solderable pins independently, you can take one of the windings and make a feedback loop from it - the way Stromberg-Carlson and McIntosh did it. Nice approach. I put the various spec sheets at: http://tinyurl.com/othertech
#5 |
Page 2 appears to be incomplete. Do you mind if I post the pages on my web page? http://www.audiophool.cjb.net/Techno.html
#6 | |
Sorry for that bug - the full page is now at the site. Thanks for mentioning it. Yes, I'm sure Partridge would be glad to see their stuff memoriallized. I'll send more Partridge stuff directly to your valuable website by and by.
#7 |
Thank you for posting those scans bentoronto!!
My amps use the WWFB 0.95's
| Partridge SE O/P transformers | Stef | Tubes / Valves | 0 | 30th July 2007 08:42 AM |
| Fender Output transformer as an audio amp part | zxx123 | Tubes / Valves | 6 | 18th January 2005 01:12 AM |
| Help needed with Audio Note DAC Output Transformer Hookup | s.hum | Digital Source | 0 | 31st October 2004 01:54 AM |
| Audio Note DAC Output Transformer Hookup | s.hum | Tubes / Valves | 0 | 30th October 2004 01:12 AM |
| Partridge Oil Filled C-Core Chokes 1H @ 500mA | mozfet | Swap Meet | 1 | 28th October 2002 07:27 PM |
| Page generated in 0.10096 seconds (76.24% PHP - 23.76% MySQL) with 10 queries |
