Standby Switch Problems
Old 25th September 2008, 01:58 PM   #1
Rodango is offline Rodango  United States
Rodango's Avatar
Send a message via AIM to Rodango Send a message via Yahoo to Rodango
Default Standby Switch Problems
I'm having difficulty with standby switches surviving in my 300W KT88-based bass head that I DIY'ed. And now that I have taken the KT88s to 600V on the plates, even my nice HIWATT standby switch was welded closed.
When I close the standby switch, I get a large "pop" and a visible arc in the switch. This happens every time the switch is closed and eventually whatever switch I put in welds together.
The Hi-Voltage PS is essentially PT -> SS Bridge rectifier -> 50uf -> 10H -> 900uf -> standby switch -> Power Amp
Should I try the switch at a different point in the circuit? Is the choke too large? I need to calm this thing down a bit....
Thanks!
Dave
Old 25th September 2008, 02:08 PM   #2
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
Supress the switch by wiring a 4.7nF Y rated capacitor across it.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 25th September 2008, 02:11 PM   #3
Corax is offline Corax  Germany
How about using a high-voltage power MOSFET doing the 'hard' switching nice and softly with a few added discrete components and replacing the manual switch at the same position?
Old 25th September 2008, 02:58 PM   #4
Ty_Bower is offline Ty_Bower  United States
Ty_Bower's Avatar
Use separate power transformers for filaments, bias supply, and B+. Put the standby switch on the AC primary of the B+ transformer. Leave the filament and bias supplies hot when you switch the B+ supply to standby.
Old 25th September 2008, 03:14 PM   #5
Tom Bavis is offline Tom Bavis
Tom Bavis's Avatar
Are there any capacitors on the load side of the switch? If so, there's a hell of a lot of energy being transferred at the instant of switch closure. The switch probably has a lower DC voltage rating than its AC rating... AC is much easier to switch since it drops to zero 120 times a seconds, so arcs don't last. I'm nut sure you can get ANYTHING except for a vacuum relay that's rated for 600V hot switching (actually more since it's unloaded).
Old 25th September 2008, 08:51 PM   #6
Rod Coleman is offline Rod Coleman  United Kingdom
работник
Rod Coleman's Avatar
I would say the problem is the high value of the 900uF cap. The standby switch is making all that energy available to uncharged valves (risking arcover if you change to cheapo KT88s. The instantaneous turn-ON current is probably enormous! Have you any EMP-damaged computers nearby?
Try a cheap inrush-suppression NTC. Use one rated the same as your HT fuse (which I guess is about 1A-1,6A for a 300W-er). Install in series with the switch. Putting another one after the bridge wouldn't hurt.
Snubbing the switch (10nF 1500V LCR Capacitors type PC/HV/S and series 10 Ohm) will also help switch life.
Stick with it though - Marshalls and Laneys and HiWatts all used to run 550V - 600V through a standby switch, so it can be made to work.
Old 26th September 2008, 01:23 AM   #7
SpreadSpectrum is offline SpreadSpectrum  United States
SpreadSpectrum's Avatar
I put a separate filament transformer in and now I switch the primary of the HV power transformer. Much easier on switches. Power transformer runs cooler now too.
AES sells a 16A 6.3V Hammond transformer for under $35. It might be worth considering if you still have a little space.
Old 26th September 2008, 02:34 AM   #8
audiowize is offline audiowize  United States
Send a message via AIM to audiowize
Wow! Switching B+... that's gutsy! I hope it was a plastic switch, this just seems very, very risky. The separate filament transformer is a good idea!
Old 26th September 2008, 07:19 AM   #9
Rodango's Avatar
Got it fixed ...
I removed the 225uf of capacitors beyond the switch and suppressed the switch with a .0039uf 1600V Orange Drop. No more fireworks. I'm sure it was the 225uf which was doing it.
I found a couple rectangular pieces of plastic under the chassis. I was trying to figure out what they were and finally realized ther were the sides of the switch! The 600V inrush current arc blew the sides off of the switch!
Thanks for the help!
Old 27th September 2008, 12:05 AM   #10
MrTransistorm is offline MrTransistorm  United States
MrTransistorm's Avatar
That's how it's done in the Ampeg SVT. The switching is nearly silent.
If you can't use a separate heater/bias transformer, try putting the standby switch directly after the secondary before the rectifiers. That way you'll be switching AC. Correct me if I'm wrong, but I believe that switches can handle much higher AC switching currents than DC because the arc extinguishes as soon as the voltage alternates. With DC the arc can remain indefinitely, destroying the contacts in the process.
Dave//
Standby Switch ProblemsHide this!Advertise here!
standby switch 9am53 Tubes / Valves 17 25th October 2010 12:24 PM
Where do you put the standby switch duderduderini Tubes / Valves 13 4th October 2008 04:39 PM
Standby Switch dre7 Tubes / Valves 6 18th October 2007 08:07 AM
Standby switch elementx Tubes / Valves 6 24th January 2006 03:46 PM
Copyright ©1999-2017 diyAudio
