Need help on resistor values for 5687 aikido kit
Old 24th September 2008, 02:00 AM   #1
atenolol50 is offline atenolol50  Singapore
Default Need help on resistor values for 5687 aikido kit
I bought the 5687 aikido kit (partial) - pcb, tubes and resistors pack.
I'd like to run the circuit on the recommended values in the userguide.
B+ 250v
R2,4 cathode resistors for input tube 6CG7 - 560ohm, 5ma
R8,11 cathode resistors for output tube 5687 - 540 ohm, 10ma
However, the resistor pack comes with 470 and 1k ohm for R2,4, 300 and 470 ohm for R8,11.
Those who also bought the resistor pack, what values did you use?
If I were to use 1k for R2,4 and 470 ohm for R8,11 do I need to use a different B+?
I've sent an email to John.B but no reply yet.
Need help on resistor values for 5687 aikido kitHide this!Advertise here!
Its alive!!! Aikido 5687 cjkpkg Tubes / Valves 20 1st September 2009 11:02 AM
DC heaters for 5687 in Aikido? RockysDad Tubes / Valves 0 29th September 2008 08:01 PM
5687 for Aikido VanguardVillage Tubes / Valves 7 5th March 2008 05:35 PM
resistor and capacitor values for Aikido preamp cbutterworth Tubes / Valves 8 26th October 2006 08:21 PM
confusion in the resistor/capacitor values and B+ supply for the aikido jarthel Tubes / Valves 1 23rd May 2006 12:58 PM
Copyright ©1999-2017 diyAudio
