diyAudio Sponsor
Old 23rd September 2008, 02:49 PM   #1
Default Continually Blowing Fuses
I have just recently put my simple se into a case. I put it together on a board to prove it some time ago, it powered up without any problems and sounded superb. Now however since installing it in a metal case I cannot get it to power up, it is continually blowing fuses.
The only difference other than the case is the fact I have installed an led taking power from the 6.3v tap. I have checked and rechecked the wiring, have any of you old hands got any ideas as to where a newbie can start looking?
Old 23rd September 2008, 03:40 PM   #2
kevinkr's Avatar
Series resistor and diode in use with that LED?
www.kta-hifi.net
Old 23rd September 2008, 03:41 PM   #3
They are, I have taken the led/resistor out of the equation and it is still blowing??
Old 23rd September 2008, 03:51 PM   #4
Zibi is offline Zibi  Poland
http://www.geofex.com/ampdbug/fuseblow.htm
Help, new PSU blowing fuses TDWesty Chip Amps 14 4th March 2007 07:29 PM
Why are these fuses blowing Darin P-B Solid State 41 30th May 2005 10:56 PM
Blowing fuses balance Tubes / Valves 2 5th March 2005 02:16 AM
blowing fuses homegrown45167 Car Audio 2 22nd October 2004 12:16 PM
The Fuses Just Keep Blowing raffir Chip Amps 19 22nd June 2003 03:49 AM
Page generated in 0.06572 seconds (75.99% PHP - 24.01% MySQL) with 10 queries
