Old 26th September 2008, 05:19 PM   #31
dsavitsk's Avatar
The moment of truth has arrived. A package from AES bearing the new, hand selected, supposedly physically matched, 71a's showed up at my door. And the verdict?
They are the same brand, clearly made in different years (probably different decades) and one is considerably taller than the other. That is to say, they are not even close. This is just bewildering.
Old 26th September 2008, 05:31 PM   #32
kevinkr's Avatar
I have had the same problem with 71A, and whats more 50% of the NOS/NIB ones I have purchased have been bad - and as you know they are somewhat expensive. I currently have a mismatched pair in my headphone amplifier and can neither measure nor hear any audible differences. (It sounds really good!)
I've also got ones that are same date code, same brand and mismatched in height so go figure..
The problem with the 71A is that it quite quickly became obsolete and only a replacement type made to keep outdated am radio receivers in operation - most were made during the worst years of the depression and QC does not appear to have been the primary consideration, either that or mis-handling of my NOS/NIB tubes must have been egregious. (Two have severely mis-aligned filaments relative to the grids, they work but are not great.)
Kevin
"Extraordinary claims require extraordinary evidence." - Carl Sagan
Old 26th September 2008, 05:33 PM   #33
HollowState's Avatar
Hmmm, the only difference I see is in the external overall height. The internal plate structure and mica supports look the same to me. I'd be more curious as to how they test.
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University
Old 26th September 2008, 08:46 PM   #34
I have been dealing with A.E.S. for probably 20+ years, from when George Fathauer still owned the company (I think he sold it ~ 1995). The only issue I ever had was a incorrect tube, something like an ECC82 instead of an ECC83 and that was long ago. I told them about it and they sent me the correct one and told me to keep the incorrect one. I just got ~$200.00 worth of stuff (mostly resistors and caps) from them. I have no complaints.
I would say that the service has fallen off over the last few years (things like picking specific tube types / brands) but when I think about it, if as a business owner you have people wanting specific tubes you are going to lose efficiency/money if you have a member of your staff spending perhaps an hour to find a couple $10.00 items.
Multiply this a few times a day.
It probably costs more to store and inventory many of the tubes they have than to sell them at a couple bucks each.
One of the harsh realities of business.
None of us are leaving this world alive. Enjoy it responsibly as you may.
Old 26th September 2008, 08:58 PM   #35
dsavitsk's Avatar
Were these $10 items, you might have a point, but that fact that they are going to be sent back again suggests that they might have saved themselves the hassle. Also, the fact that they have now lost a pretty decent customer might matter.
Old 26th September 2008, 09:02 PM   #36
dsavitsk's Avatar
Frustrating. I am working hard enough on this project to make it look nice that I'm just not willing to put up with it.
Maybe it is time to find a different tube, then. Any suggestions on a 4 pin DHT with a low mu and the lowest rp possible? Filament needs to be under 500mA or so, too.
Old 27th September 2008, 01:37 AM   #37
Would a 6A3 burning only 5V draw low enough current?
Old 27th September 2008, 01:55 PM   #38
kevinkr's Avatar
The 71A does not have particularly low rp, I think you could select the 45 as an alternative as it's rp is similar.. (It's also wonderful sounding in headphone service.) The 6B4G or 6A3 are other options and have much lower rp than the 7A or 45..
Some of the German post office DHT might work well in this application but have odd sockets and 4V filaments. You might want to look at the AA, BA, and BAS.. They are available on eBay for not obscene amounts of money and are quite linear.. Most of the information about using them is in German unfortunately as they have not traveled far afield. (Although I do have some.) RFT, Siemens and Valvo all made these types.
Old 27th September 2008, 05:25 PM   #39
Cobra2 is offline Cobra2  Norway
DIY !
Cobra2's Avatar
Send a message via Skype™ to Cobra2
I ordered a few "sale"-tubes a week+ ago (in pairs & quads), and; - all are different !!!
I guess if 10 people put in the same order, they all would get the same tube-spread.
They do however work ok.
Arne K
Ars longa, vita brevis
Old 28th September 2008, 02:38 AM   #40
I've held my peace so far, but I'm gonna say it again.  A tube with the rp of both of these, but about three times the gm, and otherwise really kewl specs (though it's not qui-ite as linear as the 71A), available, cheap, is a teevee video amplifier tube hight 6T4.  There are, of course, other very similar tubes from the era for the same duty, all with similar chars, some differing only in pinout.  I picked the 6T4 over others as a replacement to the irritatingly microphonic 6AQ5 just because Jack was holding. You might want to look at some of these, if you're not married to the gorgeous coke bottle.
They do, in their favor, have heaters that stick 2-3mm out the ends of the cathode sleeves, so they glow very romantically.
Just a data point,
Poinz
Just a rant ..... Westerp Everything Else 26 23rd May 2009 12:53 AM
USB micro-rant scott wurcer Everything Else 5 26th November 2008 01:59 PM
My rant about audio D_o_S Everything Else 17 21st January 2008 07:28 AM
Rant and survey salesmonster Everything Else 7 3rd January 2008 05:07 PM
Copyright ©1999-2013 diyAudio
