| diyAudio Sponsor | ||
#1 | |
It is a long time I have started a thread and don't even know if I am the right person to start this one, on the ETF 2008, still...
I came across the ETF website and read the following: Quote:
So, what are you bringing to the ETF 2008 shootout? Erik
my surname is indeed 'de Best': neither misspelling nor snobbism! Ask SY! |
#2 | ||
Hi Erik,
Regards, Tom Schlangen
If in doubt, just measure. |
#3 | |
which curcuit do you call 'anode follower'? Kind regards, Darius |
#4 |
Sadly, I have to miss ETF this year (but will be back next year). Stay away from Morgan and Pete, they're trouble!
My own idea for a device that could win this was something that would bring up the level by 0.5dB, but only after the measurement and level-matching was finished. A little bit of remote control technology...
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#5 | ||
(We'll drink alone) Quote:
#6 |
It's been a tumultuous several months (I ended up out of town unexpectedly while you were here), but I think after this year, life will be smoother. So I'll be at ETF09.
I really should have warned Erik to stay away from you, too.
#7 |
Heh - I once accidentally built a current starved white cathode follower using a 6922. Instead of DC coupling to the previous gain stage, it was mistakenly hooked up to the coupling capacitor for the 'hi-z' out. I was planning to have dual outs - hi-z and lo-z for driving different input impedances.
Needless to say when I plugged everything in I took some measurements and noticed my B+ was higher than expected. I gave it a listen anyways and the preamp had this - can't think of a better term - wonderful silvery sheen to the music. My friend who I was building the preamp for was suitably impressed and called it one of the best preamps he had ever heard. When I went back to figure out why the B+ was too high, I measured the voltage across the cathode resistors... it was like .1V instead of ~2.5ish. When I fixed the circuit, the 'magic' was gone and my friend complained that it didn't sound as good! |
#8 | |
#9 |
Tom
You are probably right about most amplifiers being 'sound processors'. SY is one of the few that repeatedly claims that an amp should not add/subtract nothing, therefore I joked on his contribution with the ECC82 grounded cathode. Darius I was wrong, I meant the grounded cathode. Anode follower is the straight translation from the Portuguese 'seguidor anĂ³dico' which I use at a Brazilian board (Portuguese is my mother tongue besides Dutch). SY Thanks for the kind words...don't tell them you had to kick me out as the beers were to good!
#10 |
Thank you ErikdeBest.
| RMAF 2008 - going? | igrant | Everything Else | 0 | 9th October 2008 03:49 PM |
| AES Oct 2008 SF | janneman | Everything Else | 15 | 5th October 2008 05:59 AM |
| diy show 2008 | blue934 | Multi-Way | 35 | 15th March 2008 03:20 AM |
| Decision 2008 | gurley123 | Full Range | 24 | 25th January 2008 10:55 PM |
| Page generated in 0.10962 seconds (81.20% PHP - 18.80% MySQL) with 10 queries |
