It is a long time I have started a thread and don't even know if I am the right person to start this one, on the ETF 2008, still...
I came across the ETF website and read the following:
I thought it could be a troll, but probably it is serious. My second thought was about the project brought in by SY, I think it will be an ECC82 in anode follower, with a 1k plate resistor and 40V B+, but off course I do not know the fine details here. But seriously, everybody around here is building amplifiers, preamps, RIAA stages, DAC stages (which have all had their shootouts in past ETF editions) but I barely see people building 'sound processors'. The only one I can think off is a project by Pete Millet to emulate transfer characteristics...but that one is more of an experiment than a serious item in the HI-FI chain.
So, what are you bringing to the ETF 2008 shootout?
Erik
The shootout will consist of "sound processors". These boxes operate at line level, gain equals 1, with special properties, what comes out sounds better then what goes in. Any technology is allowed, sand, vacuum, passive, you name it. Put in triodes, bipolars or dsp's and off you go. Input impedance shall be 50 k-ohm or higher, output impedance shall be lower than 5 k-ohm. Announce your contribution to me (Guido - at - tentlabs - dot - com), first come, first serve, we'll stop at 16.
Erik
Hi Erik,
Maybe not expressis verbis calling them "sound processors", but, on the other hand, sooooo many tube amps *are* sound processors, aren´t they
AISI, my tubed guitar amp would fit the requirements ...
Tom Schlangen
Tom Schlangen
anode follower ...
Hi Erik
which curcuit do you call 'anode follower'?
Kind regards,
Darius
Originally #1 posted by ErikdeBest
...My second thought was about the project brought in by SY, I think it will be an ECC82 in anode follower, with a 1k plate resistor and 40V B+, but off course I do not know the fine details here....
Erik
Hi Erik
Kind regards,
Darius
Sadly, I have to miss ETF this year (but will be back next year). Stay away from Morgan and Pete, they're trouble!
My own idea for a device that could win this was something that would bring up the level by 0.5dB, but only after the measurement and level-matching was finished. A little bit of remote control technology...
(We'll drink alone)SY said:Sadly, I have to miss ETF this year (but will be back next year). Stay away from Morgan and Pete, they're trouble!
To be considered seriously
It's been a tumultuous several months (I ended up out of town unexpectedly while you were here), but I think after this year, life will be smoother. So I'll be at ETF09.
I really should have warned Erik to stay away from you, too. Actually, his eyes are open- he met up with Morgan and me last year in Amsterdam and managed to go pint for pint with us at my favorite bar there.
Heh - I once accidentally built a current starved white cathode follower using a 6922. Instead of DC coupling to the previous gain stage, it was mistakenly hooked up to the coupling capacitor for the 'hi-z' out. I was planning to have dual outs - hi-z and lo-z for driving different input impedances.
Needless to say when I plugged everything in I took some measurements and noticed my B+ was higher than expected. I gave it a listen anyways and the preamp had this - can't think of a better term - wonderful silvery sheen to the music. My friend who I was building the preamp for was suitably impressed and called it one of the best preamps he had ever heard.
When I went back to figure out why the B+ was too high, I measured the voltage across the cathode resistors... it was like .1V instead of ~2.5ish. When I fixed the circuit, the 'magic' was gone and my friend complained that it didn't sound as good!
Re: anode follower ...
Hi Erik
Kind regards,
Darius
Erik
Hi Erik
Kind regards,
Darius
Tom
You are probably right about most amplifiers being 'sound processors'. SY is one of the few that repeatedly claims that an amp should not add/subtract nothing, therefore I joked on his contribution with the ECC82 grounded cathode.
Darius
I was wrong, I meant the grounded cathode. Anode follower is the straight translation from the Portuguese 'seguidor anódico' which I use at a Brazilian board (Portuguese is my mother tongue besides Dutch).
SY
Thanks for the kind words...don't tell them you had to kick me out as the beers were to good!
Darius
SY
SY said:Stay away from Morgan and Pete, they're trouble!
Ha!
I picked up a nice big bottle of a high-end Bourbon when I was on a business trip to Kentucky (I took a little detour to visit a few distilleries). I figured it was about the best thing I could bring to ETF from this part of the country.
This in and of itself should suffice as a "sound processor", don't you think?
I certainly will bring home plenty of Belgian beer from ETF (though most of it I will carry back as extra fat cells). After all, I don't want to disapoint the nice people at Het Anker brewery in Mechelen... I guess Morgan and I will have to drink SY's share.
Pete
SY said:Pete, you're a true Texan!
It's at times like this that I wish profanity were allowed here.
- Tubes / Valves
- Etf 2008
