| diyAudio Sponsor | ||
I have a pair of clone proAc 1SC and would like to diy a 2A3 tube amp. I found out that the audionote kit 1 with 2A3 has power of 3.5W. I'm mostly listen to vocal, and an average bass extension is good enough for me. Can this amp drive the proAc in a room of approx 350sq ft? Regards, kokheng |
#2 |
T.C.
we all have problems only some people have more than most.... long live the Magyar (Hungarians) in the world! |
#3 |
The Only way is to audition it in Your settings and Your speakers....
There is just so much that can affect the perceived sound level, the furnishings in the room, the placement of the speakers the ambient noise-levels of the location etc.etc.--Just SO many variables, Personal taste figures highly in this question as well....
Das Beste Oder Nichts |
#4 |
At a rated sensitivity of 86dB/1W/1M they're not going to play loud with a SE 2A3 amplifier. I would be inclined to contact the manufacturer to get some insight on the impedance curve and what they're thought is regarding damping factor. While you may be satisfied with the SPL level, the fact is, a SE amplifier has very low damping factor, usually low single digits. If these require some LF control the SE amplifier will simply not cut it.
Regards, KM |
#5 |
thanks for the reply.
| FS: Hitachi Router and Terk outdoor HD antenna, BD-Rom drive, Xbox HD Drive and more. | Dougie085 | Swap Meet | 0 | 3rd May 2008 07:31 PM |
| need crossover information for proac D38 (= a proac 2.5, but with 2 midrange drivers) | scipio | Multi-Way | 1 | 26th December 2005 01:12 PM |
| Idler wheel drive vs. Belt-drive | mig-ru | Analogue Source | 4 | 3rd December 2003 12:06 AM |
| Proac 2.5 clones vs Proac 2s | purist | Multi-Way | 0 | 27th April 2003 09:21 PM |
| Computer Question-Any Problems Transferring Office 97 From D Drive to C Drive | kelticwizard | Everything Else | 12 | 22nd January 2003 03:34 AM |
| Page generated in 0.09208 seconds (70.40% PHP - 29.60% MySQL) with 10 queries |
