diyAudio Sponsor
Old 19th September 2008, 07:23 PM   #1
jkeny is offline jkeny  Ireland
Banned
Default Some dumb Questions on Heater CCS supply
Forgive the basic nature of these Qs but I'm building a LM317 CCS to power the filaments of two tubes (6AR8) which each take 0.3mA heater load.
Dumb Q1 - the tubes are connected in series - should the CCS be set for 600mA (2ohm R) or for 300mA (4ohm R)?
Dumb Q2 - I'm using a regulated 12V 2A SMPS to power this (for space reasons) - does it need a higher voltage to achieve the 300mA per tube? I'm concerned the regulation might cause a problem?
Old 19th September 2008, 07:39 PM   #2
dsavitsk's Avatar
Default Re: Some dumb Questions on Heater CCS supply
Why?
300mA
Yes. At least 2x 6.3 + the CCS dropout.
http://www.ecpaudio.com
Old 19th September 2008, 08:05 PM   #3
Banned
Why? - The two tubes are a preamp addition to an existing power amp. Not enough current in the existing PS trafo & space limited.
300mA - thanks!
Aha, I feared this but thought I could parallel a 5V output from the SMPS along with the 12V. When I did this I found that it didn't give 17V but around 6.6V - something to do with the regulation I fear. OK I have a Dell laptop SMPS with 19.5V output which should do, I guess?
Dumb Newbee Questions Bluto Full Range 15 4th November 2007 01:08 PM
heater supply questions jarthel Tubes / Valves 9 13th June 2006 09:42 AM
Help! Dumb questions about a spec sheet.... Morse Tubes / Valves 15 2nd June 2004 06:04 AM
Dumb Box Building Questions Redeye Multi-Way 28 30th August 2002 11:14 AM
Page generated in 0.06922 seconds (75.35% PHP - 24.65% MySQL) with 10 queries
