diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   Calculations for an AIKIDO (http://www.diyaudio.com/forums/tubes-valves/130010-calculations-aikido.html)
gionag 19th September 2008 01:09 AM
Hi guys,
i'm intended to build an aikido pre-amp with 2 of ECC88 (6922).
the voltage i'm intended to use for B+ is 200V and then here the calculations for the PSU:
Toroidal transofmer with a primary of 225Volt / 142Volt Sec. 70 VA.
(my calculations : 200V + 1.3V(drop of rect-diodes) = 201.3 / 1.414 = 142.3V and i estimate that 50mA is enough for both channel of Aikido).
Then... for what concern the rectifing i intend to use a "silly" Gretz-Bridge with 0.01uf bypass cap on each section (of the bridge) then a 100uf ELECT cap.
I'm right ?
And ... the last thing... i based the project about the schematic on the tubecad PCB pdf : http://www.tubecad.com/Aikido_9-pin_Mono_Rev-A_PCB.pdf) Do you think it's ok ?
thanks for support
Michele
Andypairo 19th September 2008 02:00 PM
Ciao Michele,
if you haven't already bought the transformer I'd suggest to use a higher voltage (200V ac) and to "drop" the excess voltage with multiple R-C cells, in order to bring ripple to lower level.
BTW with 200V B+ be careful not to exceed dissipation limit of the Ecc88, especially on the output tubes (been there, done that :hot: )
Aikido has a very good PSRR figure but feeding it from a clean supply doesn't hurt.
Ciao!
Andrea
gionag 19th September 2008 06:28 PM
what do you suggest to me for the Rc filter ?
and... how i have to use the "heater bias" ? how does it works ? thanks !
Copyright 1999-2017 diyAudio
