| diyAudio Sponsor | ||
does anyone know about this psu design name ?
how about this design ? i wanna use this to drive my 5687 pararel single ended line stage. please advice... thanks a lot |
#2 |
That's a hybrid bridge rectifier. The "sand" diodes form the path to ground. Use UF4007s in parallel with 10 nF. high WVDC snubber caps., to keep SS diode switching noise out of the power trafo.
Eli D. |
#3 |
What the quality if compare to pure tube rectifier ?
thanks |
#4 |
Eli, do you mean the 10nF is parareled to ss rectifier ?
thanks |
#5 |
Hi Costa
5687 merit something better. Why you want to use that circuit? I think just tube it's better but 470uF after 6X4 it's wrong. I'm not sure but I remember 8uf it's the limit for 6X4 rectifier. Anyway you can use a capacitance multiplier with great satisfaction. Good work |
#6 |
The limitation is peak current - if there's enough series resistance, 4700 uF would be OK... PSU Designer (program form duncanamps.com) can tell you what the peak current is...
#7 |
oopss sorry ...
there is 47 uF not 470 uF. Do you mean the pure tube rectifier is sound better ? |
#8 |
The 10nF is connected one capacitor across each silicon diode.
Be sure your foil hat has a good low impedance ground. |
#9 | |
diyAudio Moderator Emeritus
#10 | |
| Collated Design Criteria/dimensions for Ariel ML-TL Design | talsius | Full Range | 1 | 13th October 2011 05:28 AM |
| Wilson Watt Puppy Clone Design - Design Review Please | soundengine355 | Multi-Way | 8 | 15th August 2008 02:07 PM |
| 4th order bandpass, wheel well design :) (design inside) | TWOJZ | Car Audio | 28 | 13th January 2008 02:56 PM |
| Page generated in 0.09358 seconds (77.54% PHP - 22.46% MySQL) with 11 queries |
