diyAudio Sponsor
Old 17th September 2008, 02:28 AM   #1
Default I'm new here..... :(
Hey everyone. I just joined.. I've been reading posts for a few days now. I've been playing guitar for 20 years and am JUST ow deciding I'd like to make a tube amp. I've had several over the years...JCM's, Twins, Ampegs, THD.. I really have never modified an amp or played with tube selection. My knowledge of tubes is laughable. So...... to the pint, i bought a silvertone organ amp off of ebay the other day. I found a few threads on similar chassis. Can anyone help me through converting this into a BASIC guitar amp ? Any help for the new guy would be greatly appreciated. I have pics and specs on what I have, I'll try to post it. Thanks, Carlin.
Old 17th September 2008, 04:59 AM   #2
rickl is offline rickl  United States
Carlin,
Since you want to use this for a guitar amp, I'd look for guitar amps you like using similar tube compliment.
Off the top of my head, the Matchless spitfire might be close (12ax7's and el84pp).
Or use the 12ax7 for gain and tone stack, 12at7 for the PI to drive the el84 PP. Look at the Fender field guide for ideas on similar Fender front ends and the Matchless for the outputs. I'm not smart enough to know if this will actually work.
Just be careful if this is your first amp build.
searching for jazz and a little libations.
Old 17th September 2008, 06:49 AM   #3
Here is something close to copy.
http://www.schematicheaven.com/marsh...watt_schem.pdf
The EZ81 is the same as a 6CA4
Leave the 12AT7 phase splitter as is.
Just ditch the tremlo stuff which uses the 2nd 12Ax7 which you don't have.
Ian
Old 17th September 2008, 10:26 AM   #4
Looks like a good start for an 18W 18 watt fora .
mike - www.keepingsundayspecial.org
Page generated in 0.07510 seconds (72.82% PHP - 27.18% MySQL) with 10 queries
