| diyAudio Sponsor | ||
Should I worry about driving my 6SN7's with a 12.6 vdc supply and filament voltages dividing between tubes. I'm measuring a high of 6.4
and a low of 5.9vdc. Will this have any audible consequence?? Has anyone used AC filament with the Aikido?? |
#2 |
Anyone want to take a shot at this one????? Surely not to tough for this site!
#3 |
You should be Ok wiring them in series, although if one goes open neither tube will heat and if one shorts you get the 12.6 across the other. I have my 4 wired in series and never had a problem....
Fran |
#4 |
If you're running them in series, you should have a constant current heater supply. And beware of heater-to-cathode voltage ratings!
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
| Filament wiring question | Magnetmaz | Tubes / Valves | 26 | 18th September 2010 05:37 AM |
| dc filament design question | gary h | Tubes / Valves | 9 | 3rd July 2008 02:03 AM |
| Hot running regulated dc filament supply for aikido preamp | 2004ex | Tubes / Valves | 6 | 27th September 2006 12:38 PM |
| dht p-p filament question | enochRoot | Tubes / Valves | 7 | 25th September 2005 04:31 PM |
| 5687 filament question | tone | Tubes / Valves | 47 | 22nd January 2003 02:20 PM |
| Page generated in 0.06991 seconds (72.39% PHP - 27.61% MySQL) with 10 queries |
