Old 20th September 2008, 03:38 AM   #21
Default how about.....
an 8 pin and a 9 pin on one pcb?
jd
Old 20th September 2008, 04:24 AM   #22
I have a pair of 9 pin HP PCB's with old crumbling foam on the back.
I'm sure they were made to isolate scope input tubes (6DJ8) from
microphonics. HP sockets also had heavy duty metal shields/covers.
The original tubes I found inside were branded HP by Amperex.
A small PCB like this might again serve similar function? I am not
too sure what type of foam is supposed to survive the heat though.
Obviously the original material must have gave up after 50+ years...
And that was only in the deadly heat of a garage attic in Texas.
Old 20th September 2008, 05:09 AM   #23
Some board shown at the bottom, can be fitted with standard chassis mountable sockets and a long lasting breadboard is ready.
http://ckamps.com/boards.html
Old 22nd September 2008, 05:39 AM   #24
Mazuki is offline Mazuki  United States
I'm totally up for 8 and 9 pin versions. Terminal blocks are awesome.
Old 22nd September 2008, 06:54 AM   #25
you can "just" make it out....
on my amp I put together a combo 8 and 9 pin board together with turret strips on either side (one red, one black..
http://usr.audioasylum.com/images/4/45887/22.JPG
JD
Old 22nd September 2008, 07:21 AM   #26
Geek's Avatar
Fast and fun for breadboarding
Old 30th October 2008, 05:41 AM   #27
dsavitsk's Avatar
To revive this, are people still interested in this project? I got the OK from DIYAudio to do a group buy.
I received emailed interest from a few people (I'll email those people back to see if they are still interested.)
If we can reach a reasonable number, then I am happy to put together a group buy for both 7 and 9 pin experimenter PCBs. Email sockets@ecp.cc with interest. If a few people show interest, then I'll put together the details. I'd expect ordering for a week and a half or so and boards pretty quickly after that. Depending upon the number of boards, and the breakdown of types, I'd guess between $2.50 and $3.50 per board.
Old 30th October 2008, 05:50 AM   #28
wrenchone's Avatar
I would mount the sockets in the ends of PVC pipe end caps, with bus wiire radiating out of the caps through holes or slits in the sides of the end caps. Plenty of room to tack on components, wires, etc. for "hairball" breadboarding.
Old 30th October 2008, 10:11 PM   #29
kevinkr's Avatar
Hi Doug,
I stumbled upon this thread a couple of moments ago and I am definitely interested in getting some. Are you planning on doing octals as well? (I do have octal relay sockets and can use them instead.) I'm interested in both the 7 and 9 pin sockets and would probably take 4 x 7 pins and maybe 6 of the 9 pin sockets..
"Extraordinary claims require extraordinary evidence." - Carl Sagan
Old 30th October 2008, 10:18 PM   #30
dsavitsk's Avatar
Unless there is an overwhelming demand, probably not. I think the cost of a board plus a socket plus some terminal blocks, plus some standoffs would push the price higher than the available relays.
Tube sockets 56oval Tubes / Valves 11 11th July 2008 11:01 AM
tube sockets bigpanda Tubes / Valves 1 15th June 2006 09:34 PM
Looking for tube sockets satelitis Tubes / Valves 0 8th May 2006 01:08 PM
Tube Sockets FrankRoss Tubes / Valves 4 19th March 2004 10:48 PM
Tube sockets with the same pin spacing as the tube Andypairo Tubes / Valves 5 15th March 2004 01:08 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
