Mains toroid as IT with DC balance?
Old 15th September 2008, 08:45 PM   #11
Michael Koster is offline Michael Koster  United States
Michael Koster's Avatar
Lars:
I have a lot of sketches like your schematic, but it comes
down to ? DC stability of using a CCS-loaded driver tube
to provide fixed bias. I have not tried building it yet...
Replace the CCS with a choke and use combination bias
for better DC stability and that's pretty much the amp
design I've been building. Also the choke eliminates the
3rd power supply.
I don't expect a mains toroid to perform well at line
levels though, and I've been spending up to $150
each for a good line input transformer (repeat coil)
UTC A-20s are good at about $100/pair on ebay.
Again I have not tried the toroid as a line repeat coil
but maybe a 5VA unit with a tiny core...
I would like to figure out a build like your picture some
day with CCS DC coupling, just haven't come up with
the one yet.
Ken:
Can I do a Hall-effect servo with 3 parts or less? Hmm...
Michael
Old 15th September 2008, 10:29 PM   #12
Shoog is offline Shoog
Shoog's Avatar
Interwinding capacitance is the killer in this application. I had to push 30mA of current through my driver tube to get a decent response. Even then its somewhat rolled off on the top end.
If you can design it with a 2:1 voltage step down I would expect it to perform much better. I have used one as an input transformer with a step down of 9:1 and it works great.
Shoog
Old 16th September 2008, 07:48 AM   #13
revintage is offline revintage
Michael,
I had a dedicated 1:1 line transformer in mind when I did the schematic. DC-coupling looks nice on paper but maybe is a little hazardous.
Brgds
Mains toroid as IT with DC balance?Hide this!Advertise here!
Mains toroid as MC step up? bigwill Analog Line Level 8 7th October 2008 09:18 PM
MAINS... simple, old style amplifier, plugged into mains electrical outlet (110) destroyer X Solid State 2 15th June 2008 03:31 PM
Mains toroid to step up signal bigwill Everything Else 4 20th March 2007 07:20 PM
Toroid or EE Ferrite core, which is Best for 240V mains SMPS Workhorse Power Supplies 49 6th February 2007 07:44 PM
Trade a 40V 400VA Toroid for 20V 300VA Toroid john65b Swap Meet 7 10th October 2006 04:49 AM
