| diyAudio Sponsor | ||
I've seen people ask if they can use a transformer originally intended for push/pull in a single ended application. Usually the response includes some mention of DC saturation to the lack of an air gap. Then the reply goes on to say, "Try it and let us know how it works out."
I curious to know if the exercise can go the other way. If I have a SE transformer which coincidentally happens to have a tap at 50% (presumably for some kind of UL topology), can I wire the thing up as a PP output? |
#2 |
The airgap reduces inductance, but running with balanced DC
may increase the inductance vs. running it with DC in the core. Some might worry about the winding capacitance when both ends swing with signal voltage... Try it and let us know how it works out. |
| Oscilloscope for home duty | DreadPirate | Equipment & Tools | 64 | 2nd February 2010 11:45 PM |
| SMPS Duty Cycle | gearheadgene | Power Supplies | 10 | 27th September 2008 02:22 AM |
| mid for 3 way duty | pvl1 | Multi-Way | 6 | 22nd June 2008 12:12 AM |
| heavy duty grille. | matteroftaste | Multi-Way | 0 | 24th May 2007 01:32 PM |
| What of these for sub duty? | leadbelly | Subwoofers | 25 | 22nd December 2004 07:31 PM |
| Page generated in 0.05382 seconds (78.45% PHP - 21.55% MySQL) with 10 queries |
